It is currently Tue Nov 24, 2026 2:08 pm
 Posted: Sat Oct 02, 2004 1:35 pm |
Anyone know how to remove the tensioner pulley?
It doesn't say how to in the Haynes manual...
Turbocharged400sbc
 Posted: Sat Oct 02, 2004 8:40 pm |
hey brando you talkin of the pulley/bearing or the whole tensioner? i'l asume the latter. 3.8 and 3.3L is usually remove belt and remove a single 15mm (some are 13mm) bolt down the middle of the tensioner pivot point. if i remember correctly its from the front though some engines it's on the backside (pesky quad 4's and 4 techs) some 4 cylinders the tensioner is part of the whole bracket that bolts to the front of the head and holds the AC and alt/PS on the engines (pretty sure thats only RWD like s10's though)
dude regardless it's easy!
 Posted: Sat Oct 02, 2004 9:41 pm |
Hi Brando, All
Quote: It doesn't say how to in the Haynes manual In the past Haynes has been excellent help for do it yourself maintenance, but has been slowly going downhill for the last 20 or more years.
The factory shop manual is the best choice by far.
Downside is you'd never again get to post repair questions in your own forum.
 Posted: Sun Oct 03, 2004 10:45 am |
88 Coupe wrote: Hi Brando, All Quote: It doesn't say how to in the Haynes manual In the past Haynes has been excellent help for do it yourself maintenance, but has been slowly going downhill for the last 20 or more years. The factory shop manual is the best choice by far. Downside is you'd never again get to post repair questions in your own forum. Regards, Norm
Yea....I'll get one of those shop manuals one of these days...
I replaced the pulley, but I think I need to replace the whole tensioner as the thing still makes noise, just not as loud.
 Posted: Sun Oct 03, 2004 10:59 am |
Question, is there a way to remove the tension of the tensioner?
I replaced the pulley on it, but once I got it off the tensioner went straight to the power steering pump pulley, which I then ended up using a combination of a long flathead screwdriver and a prybar to get the new one on....it just didn't seem like the correct way to do it....
Turbocharged400sbc
 Posted: Sun Oct 03, 2004 8:49 pm |
those tensioners are self contained springs with built in travel stops if it went outside the normal travel area it is def bad! and most of the time a squeak that you hear when the arm moves is because the plastic "thrust washer" has worn through and aluminum is rubing on aluminum, though some backsides of the gm tensioners are steel, all have a tang that helps it locate correctly to the bracket it bolts to.
 Posted: Mon Oct 04, 2004 8:50 am |
Brando, what kinds of noises was your tensioner making? My car has been making strange grinding noises at idle, and I am almost sure its coming from the belt-train somewhere.
How much was your tensioner pulley replacement?
 Posted: Sat Oct 16, 2004 4:57 pm |
I found out that the rough running that caused the tensioner to move so much was due to the fact that my PVC valve was bad. A quick $2 fix!
 Posted: Wed Oct 20, 2004 12:27 pm |
whats your price on the MAF? I think i ended up paying 130 dollars canadian. A new MAF will make your car purrr like new!
 Posted: Wed Oct 20, 2004 4:16 pm |
Well, I paid $43 for a reman MAF...internals were all new.
Turns out that wasn't it either, so I went back, and got an O2 Sensor after reading some things online. Now after installing the O2 Sensor, it has two error reports. One is the MAT Air Temperature is low...which is what I am going to replace. The next error code is MAP Low Manifold Air Pressure...weird thing is there is no MAP Sensor...so what's up with that? The TPS sensor reads .39 volts at idle, which is great as my shop manual says it should be between .36-.44. EGR is fine (recently replaced), PCV valve was just changed, IAC valve checks okay, Coolant Temp sensor reads okay, MAF sensor wasn't it....so I guess MAT it is.
Another thing is it runs great in the morning when it's really cold, but once it warms up, then it starts idling rough...and that damn tensioner assembly makes its unique noise...can't find a tensioner assembly anywhere, except for the pulley...so it looks like I'll have to go to the junk yard for that.
