It is currently Sun Nov 15, 2026 2:06 am
Turbocharged400sbc
 Posted: Sun Oct 03, 2004 8:54 pm |
fluid level is prob low, especially if it comes on around sharp turns etc if the system has no leaks it may be time to do a brake job! check the rear wheel cylinders too! if moist around the rubber boots they arent leaking but they may soon (Prev Maint idea here!)
with new linings and the system properly bled out the resevoir is filled to the max line so that when the linnings are worn down the light will start comming on again.
hope i could help schlim
 Posted: Mon Oct 04, 2004 9:32 pm |
Hi justinwebb, hello All
The first step is to check your brake fluid level. No one on this board can do it for you you will have to check it your self.
After you check it then post back and someone will give you the next step.
 Posted: Thu Oct 07, 2004 6:23 pm |
justinwebb wrote: yep so the fluid was low i filled it up and the light went away.....another quick question how do u know when the drum brakes need to be replaced is there a way to tell?
yep, a way to check is to put it in reverse, press the gas...and try to brake. If it stops....you're good to go!
Turbocharged400sbc
 Posted: Fri Oct 08, 2004 5:06 am |
to check whether your drum brakes need to be replaced you will need to remove the wheel then the drum and check the lining thickness/crum inner diameter are in specs and then look closely at the wheel cylinders for leaks-you may need to pry the dust boot with a small screwdriver to check for fluid behind it as this is a sign that they are starting to leak.
OldsGuy
 Posted: Fri Oct 08, 2004 6:42 am |
As important as the thickness of the brake drum lining is the condition of it and the shoes. If riveted shoes were used in the past and they were allowed to run down to the rivets then there will be score marks or even outright gouges in the drum. If you take your drums to an auto parts store that turns drums or a machine shop they will measure them for you and help you inspect them. After they give you their opinion ask them to show you and explain it. That is the best way to learn, hands on.
BTW, I have seen shoes/drum worn down so badly that it was almost impossible to get the drum off, it took a lot of beating with a mallet and wiggling and coercing the darn things. Once they were off, they were toast and needed replacement. If they are that hard to get off you are almost assured they will need replacment anyway so you get a little more "forceful" with the mallet,
 Posted: Fri Oct 08, 2004 10:02 am |
hey justinwebb... I like your new banner on the bottom of your posts... Its cool, but it just sent me into an epileptic seizure
 Posted: Fri Oct 08, 2004 7:38 pm |
Quote: yea i was bored in class so i made that....
Your new sig is very distracting but I removed it with my popup/ad blocker.
When you change it to something more appropriate, let me know so I can remove the block.
73Delta88
 Posted: Fri Oct 08, 2004 9:42 pm |
88 Coupe wrote: Your new sig is very distracting but I removed it with my popup/ad blocker
I agree, it does look cool, but it's a little big/distracting for a signature line.
 Posted: Fri Oct 08, 2004 11:53 pm |
Message Deleted. It wasn't as funny as I thought it would be.
