It is currently Sat Nov 14, 2026 1:07 am
 Page 1 of 1 [ 8 posts ]
 Post subject: cruise control fuse?
PostPosted: Sun Oct 17, 2004 1:12 am
Images: 1
where the heck is it?..i checked the fuse panel and it isnt there(no slot for c/control). where should i be looking? also, throttle sticks after car is shut off or when i brake to fast/hard. what can cause this? carbon?...thanks in advance for any help.
PostPosted: Sun Oct 17, 2004 3:54 pm
cruise control fuse is called fuse b. its in the second row of fuses from the top, on the left. it also controls the power antenna and sound system.
PostPosted: Sun Oct 17, 2004 8:42 pm
Images: 1
so if my stereo works than i assume the fuse is fine! thanks..what about the throttle problem?
PostPosted: Mon Oct 18, 2004 3:33 pm
Well your radio has 3 fuses (including that one) I would check the fuse anyway.
PostPosted: Mon Oct 18, 2004 7:27 pm
Images: 1
ok ill check! but i found out what is wrong with my throttle! the plate is catching in the bore(the bore is wearing out i guess) that is why it is sticking, therefore messing with the performance of my car. im replacing the throttle and the VSS (speed sensor) and fuel rail tommorrow. hopefully that will bring back sum life to my car.
 Post subject: Re: cruise control fuse?
PostPosted: Tue Oct 19, 2004 8:02 pm
look in ure manual.
PostPosted: Wed Oct 20, 2004 4:56 pm
Images: 1
if i had one! its hard to keep thoses around, especially since the car is 16 yrs old. and haynes is useless.
PostPosted: Sat Oct 23, 2004 9:29 am
well i got a 90 cutlass and its on the 2nd row from the bottom. ull see two 20 amp fuses, the one one the right is for internal lights, dash, cruise, that kinda stuff.
