It is currently Tue Nov 24, 2026 4:08 pm
 Posted: Sun Apr 06, 2008 10:15 pm |
Hi cutlass_is_my_first_love,
1. No more, or less, reliable that any other car.
2. Assuming you mean MPG, anywhere from 8 to 23, depending on its engine/options, state of tune, and how/where it's driven.
3. Depends where/how it's used. My daily driver is a '70 Supreme,
because it fits my needs perfectly.
4. Easy to work on. Except for normal maintenance items, not always easy to find parts.
DarkFox
 Posted: Mon Apr 07, 2008 6:13 pm |
Joined: Thu Mar 01, 2007 10:49 pm Posts: 77 Images: 3
I can't say anything about that year, but I can say that my 1979 Cutlass is also hard to find parts for.
Regular maintenance parts are easy enough, but forget cosmetic parts. I've tried finding an original shifter handle (with the little push-button) for ages. I also was not able to find the foam piece the headliner sticks to, or molding/trim for the outside of the car.
_________________ 1979 Cutlass Calais - Rolling Restoration & WIP Hurst/Olds tribute (50% complete)
Oldsmobile 350 & TH350
K&N filters
Dual 600 watt amplifier
25" I-INC flatpanel display
Xbox 360 gaming system
 Posted: Mon Apr 07, 2008 9:46 pm |
DarkFox wrote: ........ my 1979 Cutlass is also hard to find parts for ........ Apples and tomatoes. Your '79 is not a '69. DarkFox wrote: ........ I also was not able to find the foam piece the headliner sticks to ........
http://www.oldsconnection.com/forum/vie ... 5592#15592
 Posted: Mon Apr 07, 2008 10:34 pm |
91buickman wrote: year one has alot of parts available for the 69cutlass ........ And the '70, as do a lot of other vendors. Which one to use, depends on the item one is buying. 91buickman wrote: ........ alot of people are restoring them now ........ As they have been, for over 30 years. You need to try harder, to keep up. 91buickman wrote: ........ i highly recomend ........ Considering your many years of experience, and extensive resume, that is very funny. 91buickman wrote: ........ the LS-X retrofits ........ Doesn't that sound impressive? It is "salesman speak" for "Bastardize"? 91buickman wrote: ........ for any daily driven GM muscle car ........ Excellent way to slash the value of a "collectible" by a factor of ten. 91buickman wrote: ........ they are easy to install, and cheap ........ Easy and cheap? Not the kind of Girl I would take home to meet my mother. 91buickman wrote: ........ they will get better mpg's ........ How much better? 91buickman wrote: ........ than your common 4barrel small/big block.
Speaking from your many years of experience with the 49-90 Olds V8: How long will it take to recoup ones investment, (parts and labor) and start returning a profit?
 Posted: Mon Apr 07, 2008 11:15 pm |
cutlass_is_my_first_love wrote: ........ I have to see what kinda shape its in and then ill decide what to do with it ........ That will be a good start. Quote: ........ I'm kinda on a budget ........ So am I. Just means it takes longer to get it done. It also helps to know that "Year One" (suggested above, by 91buickman) sells an ignition coil, for our cutlii, for $46. My local "Kragen" sells the equivalent for $20 less. Then there is Autozone for $25 less. Quote: ........ any suggestions on cheap and good replacement parts ........
"Cheap" and "good" is a rare combination, but there are still a few exceptions.
Let us know when you find out what you want/need.
 Posted: Mon Apr 07, 2008 11:39 pm |
91parkave wrote: year one has alot of parts available for the 69cutlass, alot of people are restoring them now, so many aftermarket parts are available, There are many common parts available for these cars through your local autoparts store. The A-body was a very popular platform, and unless you need "resto quality" parts, or need parts only they offer, or have the desire to spend more than you need to for a daily driver, you can use the local parts store to your advantage. Quote: What are your plans for the engine? i highly recomend the LS-X retrofits for any daily driven GM muscle car, Have you ever performed this swap? It's hardly what one would call a "retrofit". Quote: they are easy to install, and cheap, not to mention they will get better mpg's than your common 4barrel small/big block.
Easy in what way?
Cheap? Last I checked, the local boneyard wanted 5k for a LS1 in unknown condition, with wiring and computer. I'd hardly consider that cheap. Not only will you have to either modify or buy a new harness, which last I checked the Painless harness is 600 bucks, but you also have to fabricate motor mounts, or buy adapter plates, and get all the engine accessories to fit in the available real estate.
I don't really consider 7-10k a cheap venture at all.
Fuel mileage really isn't much different. A LS1/auto Corvette gets 17 city, 25 Highway, and that's with an OD transmission and a body that is much lighter than the Cutlass is. I wouldn't expect fuel mileage to rise much at all, when compared to a properly maintained engine with a carburetor.
Consider this- The OP could, for half the price of a junkyard engine, buy all the necessary components to install an EFI system on his existing powerplant.
Or for 1/7 the price, he could buy a new carb to run the car on E-85 and enjoy not only the high octane rating of that fuel, but he could enjoy the cheap fuel. He won't net the gas mileage that he would with regular fuel, but if it's cheap enough, there is still financial gain there, at least indirectly.
Or, for no more additional investment that he would already be making for normal maintenance, he could tune the car for maximum economy with the components the car already has.
EDIT- Two posts while I was composing- sorry for any repetition.
91parkave
 Posted: Tue Apr 08, 2008 8:31 am |
......ill start with clown first....
To start with
Yes year one sells parts for the Cutlass, as do many others, year one however has more available then autozone will, i would know i used to be a PSM there for 2 years. No one ever said what parts he might need so your comparison of autozone and yearone is invalid, in that respect, as far as engine parts, If the car comes with a olds engine, then autozone can get your parts for that no doubt but then again so can ebay, there are alot of places to get them from. as far as bastardizing the olds, well thats why i asked th op what plans hehad for his engine combination, not you. I dont see how you speak for other people instead of letting them make up their own minds, also to note: if you score a olds cutlass with a numbers matching block and such then by all means keep that motor but more than likeley its been changed already which is why i told the op..not you....to check out the LSX retrofits. and speaking of investment, to turn out profit, lets see which one would sell for more a 69 Cut with a non numbers matching olds motor....or a LSX/XXXX retrofitted non numbers matching car,  i know which one alot of people would put their money on. then again you could add the stylish autozone hub caps like norm and add more value to your car.
Andrew:
Have i performed this swap......yes If its not called a retrofit what you call it?
if you paid 5 thousand for a ls1 thats your fault, down here there around 1500 dollars the truck motors are even cheaper (4.8,5.3,6.0 ) and make just as much power, and all the parts are interchangeable, you can get a 5.3 with trans for around 900 with everything. Using painless is stupid IMO you can use factory harness, for free, just hook up the your required power sources, get your PCM reprogramed and your in the game, my PCM cost 75 to get done. all in all in my 70 swap im about 1200 in the hole. MOtor mounts?? lol a piece of 1/4 flat stock drilled out using the template from www.ls1tech.com cost to me--10bucks including drill bits.. and the Trans cross member tab--flippped around and welded back 3 for the 3 degrees of pinon drop.
Now for the op:
This is no more than another way for you to go on your project. You can listen to batman and robin mentioned above, they made a couple of valid statements, but in the end its up to you, thats why i asked for your plans, not theirs. Whichever way you go, i wish you the best of luck, and hopefully youll find something that works for you
 Posted: Tue Apr 08, 2008 9:01 am |
91parkave wrote: Yes year one sells parts for the Cutlass, as do many others, year one however has more available then autozone will I don't think that was ever disputed, it looks to me like the point was brought up that Year One is damned expensive. Quote: there are alot of places to get them [parts] from. That was the point, as I read it. Quote: Have i performed this swap......yes If its not called a retrofit what you call it? I would call it a custom conversion. The definition of retrofit that I was taught is "the incorporation of new design parts resulting from an approved engineering change to an item's current approved product configuration documentation into already accepted and/or operational items." Which is apparently how the Navy defines it. After looking in the dictionary, I suppose you could call it a retrofit. Quote: if you paid 5 thousand for a ls1 thats your fault, down here there around 1500 dollars the truck motors are even cheaper (4.8,5.3,6.0 ) and make just as much power, and all the parts are interchangeable, you can get a 5.3 with trans for around 900 with everything. Are they hot? That sounds ridiculously cheap to me. Quote: all in all in my 70 swap im about 1200 in the hole. Care to share a pic or two? Quote: You can listen to batman and robin mentioned above, they made a couple of valid statements, but in the end its up to you, thats why i asked for your plans, not theirs.
I fail to see where anybody told the OP what to do-
 Posted: Wed Apr 09, 2008 2:36 am |
91buickman wrote: ........ year one however has more available then autozone will ........ Try to keep up with the rest of us. Here it is again: 88 Coupe wrote: ........ Which one to use, depends on the item one is buying ......... Which part of "depends" do you not understand? And again: 88 Coupe wrote: ........ as do a lot of other vendors ........ For example: OPGi, Fusick, Kanter. Tanson, Five points, GM Obsolete, Parts Place, Supercar Specialties, Egge Machine, National Parts Depot, and Supercars Unlimited. Just to name a few that have good reputations. I do not know that I would put "Year One" at the top of the list. 91buickman wrote: ........ No one ever said what parts he might need ........ And no one ever said what engine he might need. 91buickman wrote: ........ your comparison of autozone and yearone is invalid ........ It is the same part and the prices are different = The comparison is valid. 91buickman wrote: ........ If the car comes with a olds engine, then autozone can get your parts ........ Sometimes yes, sometimes no. Some parts are in stock, some are not. No different than any other supplier. 91buickman wrote: ........ thats why i asked th op what plans he had for his engine combination ........ We all know why you asked. Because you need to showcase your vast knowledge of that product. This was clearly shown, by your eagerness to add your "recommendations" along with the question. Here is is again: 91buickman wrote: ........ What are your plans for the engine? i highly recomend the ........ Why did you even bother to ask? 91buickman wrote: ........ I dont see how you speak for other people instead of letting them make up their own minds ........ This is where you are supposed to "post the quote" so we will all know WTF you are talking about. 91buickman wrote: ........ stylish autozone hub caps ........ I am sure the original owner would have appreciated your comment. I would pass it along to him but, unfortunately, I bought the car from his estate. The "before" pic was taken at the time the car was delivered.  The "after" pic, that you see now, was taken the following day, after I switched tires and wheels. Easier to explain my pic, than yours.  91buickman wrote: ........ Have i performed this swap......yes ........  When you finish with it, let us know if it runs any better than your Buick. http://www.3800pro.com/forum/naturally- ... g-etc.html . 91buickman wrote: ........ You can listen to batman and robin ........
Since, one of them actually has some experience with '60s Oldsmobiles, and the other has a bit more, that would be his logical choice.
DarkFox
 Posted: Wed Apr 09, 2008 8:30 pm |
88 Coupe wrote: DarkFox wrote: ........ my 1979 Cutlass is also hard to find parts for ........ Apples and tomatoes. Your '79 is not a '69. I understand that. Just throwing out there that a car thats a decade YOUNGER is hard to find certain parts for, thus re-enforcing (I'm agreeing with you) your quote. 88 Coupe wrote: 4. Easy to work on. Except for normal maintenance items, not always easy to find parts.
88 Coupe wrote: DarkFox wrote: ........ I also was not able to find the foam piece the headliner sticks to ........ http://www.oldsconnection.com/forum/vie ... 5592#15592
I appreciate the suggestion, but what I'm saying is that the actual INSERT, the big foam part, was cracked in half, all the corners were broken off, and was almost beyond any hope of repair. I wasn't attempting to do the fabric , my intention was to take it to the fabric shop. However, it was in such crap shape that the remaining headliner fabric was all that was holding the pieces together.
I spent beyond two days with a hot glue gun, small clamps, and about two rolls of duct tape before I could take it to the fabric shop. It looks brand new in the car, but damn, it looks like it got run over a few times, burnt, crushed, and taped back together again.
Also, why did this thread turn into such a bonfire?
K&N filters
