It is currently Sun Nov 08, 2026 2:06 pm
 Posted: Fri Aug 17, 2007 11:45 pm |
91parkave wrote: 88delta88 wrote: 91parkave wrote: ....as for the exaust issue you can have the pipe ceramic coated or take the heat shield off and wrap aluminum foil around the pipe with several layers to avoid the heat escaping from the pipe. .... Ouch...  Doesnt it hurt to shoot yourself in the foot? am i missing the humor in that? plese clarify what youre making a remark to
I guess I wasn't digressing with the thermodynamics remarks-
Aluminum Foil reflects heat, like other aluminum parts. The problem is that it would be a direct conductor and radiator of heat since it would be in direct contact with the pipe. In other words, temps would increase, not decrease.
 Posted: Fri Aug 17, 2007 11:58 pm |
91parkave wrote: ........ get my name right ........
I did get it right. Right off the Bonneville Club forum.
http://www.bonnevilleclub.com/forum/vie ... p?p=899656
The entire thread was an interesting read.
 Posted: Sat Aug 18, 2007 12:28 am |
91buickman wrote: Nothing that has not already been covered here. If I missed something, post the quote. 91buickman wrote: ........ a 86 cutlass with a 383 and 3.73 gears but was stolen from me ........
You earned points for not calling it a "stroker" and lost them for claiming to have a Chev in your Olds.
That aside, it is history. You claimed to have an Olds. You have a Buick. Because of it, you lost even more credibility.
 Posted: Sat Aug 18, 2007 12:45 am |
afrats wrote: ........ Isn't that a prereq to be on these forums?
Ownership of an Olds is not required. Olds related discussions are why we are here.
Brand X discussions are welcome in the "Off Topic Lounge".
 Posted: Sat Aug 18, 2007 1:38 am |
91parkave wrote: ....am i missing the humor in that? plese clarify what youre making a remark to.....
You have been bashing aluminum for its high heat transfer characteristics, and, now you are recommending we use it to keep heat from escaping?
 Posted: Sat Aug 18, 2007 6:35 am |
I knew I missed one.
91parkave wrote: ........ Bonneville club dissed the PVc when i brought it up because they THINK it would release toxic fumes from it warping ........
Your sewer pipe is not PCV.
91parkave
 Posted: Sat Aug 18, 2007 7:43 am |
88 Coupe wrote: I knew I missed one. 91parkave wrote: ........ Bonneville club dissed the PVc when i brought it up because they THINK it would release toxic fumes from it warping ........ Your sewer pipe is not PCV. Norm
Clown are you seriously telling me that from my pictures of intake you can tell its not PVC? please share with all of us how you can figure that out. Until then go visit your local home depot or lowes and look for youreself
91parkave
 Posted: Sat Aug 18, 2007 7:52 am |
88delta88 wrote: 91parkave wrote: ....am i missing the humor in that? plese clarify what youre making a remark to..... You have been bashing aluminum for its high heat transfer characteristics, and, now you are recommending we use it to keep heat from escaping?
read every post i made about aluminum again. notice the heat soak comments i made then think about how that would apply to what i said. Alumium foil with the shiny side towards the pipe layere after layer acts as a insulator relfecting heat back into the pipe the layers allow the outside to be cooler. I can vouch for that because ive done it. i can touch the pipe for a couple of seconds with my bare hands and not get burned withe car running.
 Posted: Sat Aug 18, 2007 10:05 am |
91buick wrote: ........ are you seriously telling me ........ Yes. I saw sewer pipe. Your sewer pipe is not PVC. 91buick wrote: ........ then go visit your local home depot or lowes and .......
No need to. The sewer pipe they sell is not PCV.
91parkave
 Posted: Sat Aug 18, 2007 3:05 pm |
87Delta wrote: Black sewer pipe is ABS. Typically found in trailers and alot of new construction.
I dont have black sewer pipe its painted black. Sewer pipe is thin walled my PVC pipe is thick walled. either way it goes whats your point?
 Posted: Sat Aug 18, 2007 3:27 pm |
91buickman wrote: ........ its painted black ........
I am surprised.
Black attracts heat. Is your goal to heat the incoming air?
91parkave
 Posted: Sat Aug 18, 2007 3:36 pm |
88 Coupe wrote: 91buickman wrote: ........ its painted black ........ I am surprised. Black attracts heat. Is your goal to heat the incoming air? Norm
alright clown so in a dark enviorment i dont see the black paint attracting any more heat than any other color. We all know black attracts more light energy but when there is no light present than what makes it any diffrent from white,blue,purple etc....
