It is currently Sun Nov 29, 2026 8:15 am
 Posted: Wed Feb 01, 2006 11:36 am |
Timothy, I think you missed the hint of sarcasm floating around this topic...  I dont think 88coupe was seriously suggesting you replace your FWD 6cyl with a RWD 8cyl beast. But it could be done. Thats what he was getting at. Do the benefits outweigh the cons?
 Posted: Wed Feb 01, 2006 12:09 pm |
88delta88 wrote: replace your FWD 6cyl with a RWD 8cyl beast
who said it had to be RWD?
 Posted: Wed Feb 01, 2006 4:31 pm |
Timothy McVeigh wrote: ........ it's a family car... in case you hadn't noticed...
Sorry, I did not notice.
 Posted: Thu Feb 02, 2006 10:17 am |
why not a cadillac 4.5L??? almost a direct swap!
Just kidding, those motors are garbage... I worked on one once. Horrible experience. Trying to find parts, or a mechanic that didnt just laugh at me for working on that motor.... But its a v8!
Northstar, my friend, buy a northstar...
Timothy McVeigh
 Posted: Thu Feb 02, 2006 12:12 pm |
yeah, I've heard horror stories about those old caddy engines... *shiver*
I was considering that at one point in time... I don't have anywhere near the income necessary for that
Then there's all that custom fabrication... and ENGINE BAY SIZE
I have the older 3100... without roller rockers and the revised intakes
Those, plus the slight increase in bore should make things a bit more lively (I'm also adding a 62mm throttle body to it)
If I could find one cheaper than those off rsm...
 Posted: Thu Feb 02, 2006 12:14 pm |
Timothy McVeigh wrote: The closest match for a fwd v8 would most likely be the 5.3l found in the new Impalas... but I doubt it would fit in my car
no.....FWD 455
 Posted: Thu Feb 02, 2006 5:13 pm |
Brando wrote: ........ no.....FWD 455 Exactly. It'll work in the front or rear, take your choice. Timothy McVeigh wrote: you find one, let me know
They're frequently on Ebay.
EDIT: Search Ebay for Toronado engine. All I found was an earlier 425. Heres the link.
 Posted: Thu Feb 02, 2006 5:28 pm |
88delta88 wrote: why not a cadillac 4.5L??? almost a direct swap ........ Not as difficult as a BBO but very doable. I would recommend any Cad V8, except the 4100 series. 88delta88 wrote: ........ Northstar, my friend, buy a northstar...
Best choice, but also the most expensive to purchase.
 Posted: Thu Feb 02, 2006 5:39 pm |
88delta88 wrote: ........ I dont think 88coupe was seriously suggesting you replace your FWD 6cyl with a RWD 8cyl beast. ........
I was not. Converting FWD to conventional RWD is not something I'd normally suggest to a hobbyist.
Regards, Norm.
Timothy McVeigh
 Posted: Fri Feb 03, 2006 8:52 am |
I'm not interested in the old caddy engines *shiver*
The northstars ARE too expensive
RWD was never even considered due to it's lack of discernable benefits (and widespread popularity... I'm a nonconformist)
I think I'll just wait for the DOD equipped pontiac g6 gtp coupe
