It is currently Fri Nov 13, 2026 8:08 am
86Delta
 Posted: Sun Dec 28, 2003 6:47 pm |
hey brando,
that weird injection set up you are talking about is TBI, throttle body injection. it has the injectors in the throttle body, not in the intake runners at the ports. very common on GM trucks.
 Posted: Sun Dec 28, 2003 11:32 pm |
86Delta wrote: hey brando,
Ahh...got ya, the older S-10 used the same engine, didn't it?
73Delta88
 Posted: Mon Dec 29, 2003 9:50 pm |
86Delta wrote: oldsmobile420 wrote: yea it will cuzim wildin outon dis car and im sick of these ricers what? all i understood was i'm sick of these ricers.
glad I wasn't the only one....
86Delta
 Posted: Tue Dec 30, 2003 3:58 am |
yeah older S-10's also used the 2.5L. they are good engines for the most part and with the exception of the placement of the coil packs they are pretty easy to work on. just today i pulled the head off of a 92 century with a 2.5 because it has a stuck valve, did that in a little over an hour.
but as far as performance goes, i say sell the car and get one with a V6 in it. i think it will be more trouble than its worth to convert the car to a V6, unless you have a donor car sitting right there. it certainly isn't a drop in job, things like the AC accumulator have to be moved and you'd have to get a trans for a V6 too, not sure if the 4cyl trans will take the abuse.
 Posted: Tue Dec 30, 2003 9:37 am |
Hey 420... Make yourself up a cheap custom intake... It'll add a little, and if not, it'll sound cool...
 Posted: Wed Dec 31, 2003 10:12 am |
Flip the cover over on your air cleaner!
MEXICAN SUPERCHARGER
If you want to smoke the ricers out instead, put a bottle of "mother's blue" blue jean dye in the tank, and watch them cough to death... You wont have to worry about beating them then. You should see what this stuff does when you put a couple drops in a lawnmower!!!!
73Delta88
 Posted: Wed Dec 31, 2003 6:43 pm |
88delta88 wrote: Flip the cover over on your air cleaner!
haha... I did that on my 73, I did notice a difference especialy on the highway where I'm cranking higher RPM's
it has a little more power but when I stomp on whe gas it goes "WOOOOOOOO" reeeeallly loud... hahaha
 Posted: Thu Jan 08, 2004 5:59 pm |
The sound is cool! I had an 84 caprice with a 305... Man that thing would whine like a bitch when I had the throttle wide open with my mexican supercharger! Suprised some people!
Cutlass95Ciera
 Posted: Thu Jan 08, 2004 9:57 pm |
85cieraholiday wrote: . If you want a street racer, get a Cutlass Supreme or a Ciera with the 3.8.
My fealing exactly \:D/
DKnight
 Posted: Fri Jan 09, 2004 1:07 pm |
Or a Delta 88. 8)
DK
_________________ One man can make a difference. One man made all the difference.
BigBlockOlds
 Posted: Fri Jan 09, 2004 1:24 pm |
468/T-56/3.73
85cieraholiday
 Posted: Mon Jan 19, 2004 12:41 pm |
In the time I have spent with my 2.5 litre 4 cylinder in my Ciera, I can say THIS ENGINE IS NOT FOR SPEED! If you really want speed, get a Ciera with the 3.8 or get a Cutlass Supreme. If you just want a car that will start every time, keep the 2.5, but if you need to burn street racers, YOU GOT THE WRONG CAR! In summary: 2.5 litre 4: good on gas, starts every time, other then the small oil leak it has no big problems;but street races are  with it!
_________________ .
