It is currently Tue Nov 10, 2026 5:16 am
 Page 2 of 2 [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 27, 2004 6:28 pm
Images: 12
nwmaximus wrote:
Thanks,I was hoping for a little more than that.I guess the dual exhaust will help some...maybe 15 HP more? And I will eventually tune the carb better or get a new one.Whats the cheapest/easiest way to free up some ponies,besides the headers & exhaust...manifold and cam? :?: And what about swapping out the TQ convertor?
Manifold, yes, cam, yes. Those 2 are also factors in HP. The torque converter however has no effect on HP, unless for some odd reason it like weighs more or less which makes it easier to spin that heavy thing, but overall, generally you dont change torque converters to add HP
-Shadow's Rides-
PostPosted: Sat Mar 27, 2004 8:03 pm
Yeah,I guess I meant a Holeshot 2000 will probly get me off the line better-if that was the case.A little more application of TQ?
PostPosted: Sat Mar 27, 2004 11:57 pm
Images: 3
Changing torque converters can help in the sense that if you buy a good one (like Coan, JW, etc) they will be more effecient at transfering the power from the engine to the ground which is like adding horsepower. Although your not really adding horsepower your just freeing up some horsepower that was otherwise being wasted.
Do you have a stock rear gear? I can't see a higher stall converter doing you any good if you don't have some decent gears, bigger cam, better air and exhaust flow, etc. You have to think of the entire driveline as a combination. Not just individual pieces.
468/T-56/3.73
PostPosted: Sun Mar 28, 2004 2:44 am
I'm actually putting the Holeshot 2000 in my Vette,its already got a cam that needs more converter.I know a converter does NOT add HP,it just makes it feel like extra TQ off the line.I will be addressing the Cutlass driveline later.Just trying to get some input from some of you that have already tackled the stuff I'm planning.Most of this is new to me,since most of my former rides came with more power to start with.I'm not sure what the rear gear is on my '78,since I havent had it that long.Its probly the stock setup,whatever that is.
PostPosted: Thu Apr 01, 2004 1:14 am
my 85 3.8L has 125HP@4400rpm and 195ft-lbs@2000rpm
the torque rating seems about right but the HP rating seems a bit 2 low, i dont have anything to comfirm it though, anyone know?
PostPosted: Thu Apr 01, 2004 11:15 am
I don't know because I have never had the car on a dyno since the engine was rebuilt (never had it on before either). My butt dyno says it's pretty good though :lol: :lol:
PostPosted: Thu Apr 01, 2004 2:01 pm
speedy266- the numbers you have are correct for the factory 3.8 in 1985 for your car.
PostPosted: Sat Apr 03, 2004 1:46 am
dam only 125HP, no fun, i think i'll increase the compression ratio next time i rebuild it.
