It is currently Fri Nov 13, 2026 7:07 am
 Posted: Mon Nov 01, 2004 3:11 pm |
Hi rage03usa, All
You have a PM.
 Posted: Mon Nov 01, 2004 5:12 pm |
Hi rage03usa, All
Here is a good deal on some quality parts to put away while you save for the rest.
He is also very knowledgeable in the areas where you need help.
 Posted: Tue Nov 02, 2004 9:47 pm |
rage03usa wrote: my Uncle (39) died of a heart attack thursday morning, leaving behind a 6 yr old daughter...
Very sorry to hear that, is your Aunt still alive?
73Delta88
 Posted: Tue Nov 02, 2004 9:56 pm |
my condolences to you and your family.
rage03usa
 Posted: Tue Nov 02, 2004 10:51 pm |
Brando wrote: Very sorry to hear that, is your Aunt still alive?
TOC Admin Brando 73Delta88 wrote: my condolences to you and your family.
yes, she is still alive, and thanks for your support guys. i just heard back from the guy with the pistons, ill be getting them soon.(Thanks norm) 8)
 Posted: Sat Nov 06, 2004 6:24 pm |
Hi, rage03usa, All
Quote: still no response from that contact you sent me norm...
Sorry to hear about your Uncle.
Bill has more going on right now than I thought. I was hoping he could help because he's closer to you.
Using J&S for machine work would involve shipping charges, but they are one of the best.
Talk to him about your options.
He might be able to work with you to make sure your local machine shop gets the "Olds specific" work done right.
Good to hear you're getting off to a good start. What are the cam specs?
 Posted: Sat Nov 06, 2004 7:07 pm |
Hi rage03usa, All,
Quote: 204-214@ .05 .448-.472 lift
Good choice for where you are right now.
 Posted: Mon Nov 15, 2004 5:54 pm |
Hi rage03usa, All,
Quote: ........ i was over at 442.com in the F.A.Q............. There is a lot of good information on 442.com, but there is some that has not been corrected yet. Quote: listed for building up a 350 was to use #5 / #7 heads.......... i have both 5a and 7a heads laying around .......... I understand, flow wise, the 5a is only a little worse that the 7a.
The heads you use will depend on the 350 you are building.
What heads came with your 350?
I'll need to verify what I'm thinking before I answer, then I'll be back.
 Posted: Mon Nov 15, 2004 11:02 pm |
Hi rage03usa, All
Quote: the 350 came with 3a heads.... The best SBO head to bolt on unported, is the 5.
If, when reading the 7a, the a is smaller and lower than the 7, it and 7 would be better because they already have hardened valve seats and flow is almost as good.
Next choice is 5A, and since you already have a pair, it's probably your best choice.
The other 7A (A in a direct line next to the 7) has larger combustion chambers (lower compression) and will have problems bolting onto the 350.
When it comes time to get the heads done it's important to use a shop that knows how to set the correct installed valve height to achieve the installed spring height. Not even a consideration with SBC.
