It is currently Thu Jun 18, 2026 4:25 pm
 Page 12 of 12 [ 169 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12
 Post subject: Re: cold Air Intake
PostPosted: Thu Aug 23, 2007 12:09 am
page 3 norm,
91parkave wrote:
........ Again, how does that affect the air flowing through it?
heat soak affects incoming air, its constantly moving...yes...but also affected by the tube it runs through.
Think of a aluminum water pipe if i torch the pipe constantly the water going through it will be at a higher temp same thing with airflow-hot pipe hot air. If youre only drag racing its not a issue but for a daily driver it is. thus the term "heat soak"
PostPosted: Thu Aug 23, 2007 7:49 am
91buickman wrote:
........ if i torch the pipe constantly the water going through it will be at a higher temp ........
What is the wall thickness, diameter, and length of the pipe?
How much heat, and how much area is it being applied to?
How many CFM is the water moving? At what pressure?
What is the actual change in water temp?
How would your analogy compare to the heat transfer seen in an automotive cooling system?
PostPosted: Sat Nov 03, 2007 9:23 pm
your local home depot sells sections of PVC piping you can make one using that, or pepboys sells sections of intake tubing for anything custom
Your half right.....water is more dence than air, the rate at which the air is moving through an engine is far faster than water could, so that isn't a very good comparison between a water heater, and a space heater because the space heater is creating temps far above any engine would see just to heat the air enough to fill the room... lol, no offence....
Using things like that metal flex tubing isnt as effective to draw the air through because the bumps inside the pipe are creating turbulance, but it does well with guiding outside air being blown through it.... the duration of time it takes for the air to flow through an airfilter, through the intake, throttlebody, manifold, and finally to the heads, the air doesn't have too much time to heat up....reguardless of "heatsoak"....the term is typically a danger when dealing with forced induction and not N/A cars....
Besides that, the computer adjusts timing and fuel based on the temp of the air flowing through it so i wouldnt worry too much about it....you will see gains in power and responce based on the temp or the air going through it, which is why CAI's typicaly make more power, but typicaly you see gains at higher RPM's due to the longer pipes required than a WAI or "short ram intake"
PostPosted: Mon Nov 05, 2007 2:10 am
gptuner wrote:
........ no offence ........
Not possible to offend someone who is no longer here.
gptuner wrote:
........ Using things like that metal flex tubing isnt as effective to draw the air through because the bumps inside the pipe are creating turbulance ........
That is what 91buickman said, at the top of page three. Not one of the two (or three?) times he was correct.
As a matter of fact, I think, everything in your post was already discussed in the past 12 pages of this thread.
In the future, I suggest you take the time to read the entire thread, before you reply.
