It is currently Mon May 04, 2026 8:48 am
DrJay
 Posted: Tue Jun 14, 2005 7:46 pm |
88 Coupe wrote: Hi all. DrJay 88 Coupe wrote: .............. how do you increase duration by changing rocker ratios? Not "Rocket science". The answer is/was taught in first year High School during Auto Shop and/or General Science. We have been waiting for DrJay to answer, since June 2. Regards, Norm
You are seriously one strange person. I said rockers increase duration, you said an increase in duration would help performance but "how do you increase duration by changing rocker ratios?" It would seem fairly obvious that you were asking me to explain it because you didn't understand it. But now you're playing it off like you were quizzing me? Wouldn't it seem that seeing as I brought it up I would at least know about it? Do you somehow think I just typed words that came to my head and by pure coincidence they came out like that?
You're a very tough person to have a conversation with. Feel free to email me though, if you're interested in learning about rockers and cams I'd be more than happy to share info with you.
_________________ www.SeriesOnePerformance.com
Catering to 88-95 Series One 3800 engines and vehicles. Cams, Rockers, Cold-Air Intake kits, Brakes, Aftermarket and OEM Pieces, Special Requests, we can handle just about anything!
 Posted: Tue Jun 14, 2005 10:37 pm |
Hi All
DrJay,
88 Coupe wrote: .............. how do you increase duration by changing rocker ratios? 88 Coupe wrote: Not "Rocket science".
We have been waiting for DrJay to answer, since June 2. DrJay wrote: It would seem fairly obvious that you were asking me to explain it because you didn't understand it. But now you're playing it off like you were quizzing me? Wouldn't it seem that seeing as I brought it up I would at least know about it? Do you somehow think I just typed words that came to my head and by pure coincidence they came out like that? Since none of us know the answer, would you please explain it for us? DrJay wrote: Feel free to email me though, if you're interested in learning about rockers and cams I'd be more than happy to share info with you. Having a little problem working in front of an audience? There are more than a few here with the same grasp of the basics as I have. We would all like the benefit of your knowledge. In the first line of your first post, you made a statement. A question was asked about that statement, and you still have not answered it. 88 Coupe wrote: .............. how do you increase duration by changing rocker ratios?
Please answer the question. If you cannot, please say so.
EDIT: The pun was intended
 Posted: Wed Jun 15, 2005 12:36 am |
Hi all,
DrJay,
DrJay wrote: Feel free to email me though, if you're interested in learning about rockers and cams I'd be more than happy to share info with you. Right after we finish here. 88 Coupe wrote: If you have any questions concerning flow characteristics or valve train geometry, please start a thread here.
Actually, I learned quite a bit at http://www.yellaterra.com.au/index.php
 Posted: Thu Jun 16, 2005 2:58 am |
Hi abbike18, All,
Quote: what is the stock rocker ratio on series 1 3.8 liter engines?
I thought the rocker salesman would have answered you by now.
I believe they are 1.6, but DrJay says I have no experience with 3800 engines so you'll need a second opinion.
 Posted: Fri Jun 17, 2005 9:12 pm |
88 Coupe wrote: Hi abbike18, All, Quote: what is the stock rocker ratio on series 1 3.8 liter engines? I thought the rocker salesman would have answered you by now. I believe they are 1.6, but DrJay says I have no experience with 3800 engines so you'll need a second opinion. Regards, Norm
yep, 1.6:1 Rocker Arm Ratio
 Posted: Fri Jun 17, 2005 10:05 pm |
Hi All,
Brando wrote: yep, 1.6:1 Rocker Arm Ratio
Thanks.
 Posted: Fri Jun 17, 2005 10:34 pm |
Hi All,
For anyone that might still be following this thread.
DrJay wrote: Higher ratio rockers are known to increase duration slightly. This is documented on a number of websites and in books. I hope you take the initiative to look it up yourself. DrJay wrote: You are seriously one strange person. I said rockers increase duration, you said an increase in duration would help performance but "how do you increase duration by changing rocker ratios?" It would seem fairly obvious that you were asking me to explain it because you didn't understand it. But now you're playing it off like you were quizzing me? Wouldn't it seem that seeing as I brought it up I would at least know about it? Do you somehow think I just typed words that came to my head and by pure coincidence they came out like that?
It's obvious DrJay would rather evade, than answer the question.
Has anyone wondered why? I see four possible reasons:
1) He doesn't know the basics of valve train geometry.
2) He doesn't know the answer.
3) The statement is false.
4) All of the above.
Turbocharged400sbc
 Posted: Sat Jun 18, 2005 2:00 pm |
hiya Norm!
I am wondering if DrJay just might be confusing a couple of things regarding higher ratio (numerically) rocker arms...
with camshaft duration and lift specs the same a high ratio rocker will accelerate the valve off the seat faster and close it faster though the ramp profile of the cam remains the same, if I am remembering correctly this increases the area "under the curve" which has a similar effect to increasing a cams duration...to a point.
valve lift (total)is increased at every point of the lobe profile but the valve opening faster and closing faster (one reason stiffer springs are recomended-to control valve bounce/float which would occur at a lower rpm than with stock rockers) is one of the reasons that a higher ratio rocker increases performance-more air+more fuel = more power.
most ECM's have a certain range of value's that it is adaptable so a lifter install will give you more power but for the best power computer/tunning modifications will be neccisary as with any internal combustion engine.
hope I have contributed my 2 cents....hehe
Oh we are TIGing the 10 point cage into the 442 this weekend as well as installing the two 5 point camlock G force racing harnesses (Al also got a helmet and one fer the wife-he says he's gonna make her give him a BJ with her wearing her helmet....lol  )
So hopefully no tracks will have a problem with us running the car since we have way more safety equipment than is required....and amanda cant kill me if her hubby does sumthin stupid.....
Schlim
 Posted: Sat Jun 18, 2005 7:02 pm |
Hi Turbocharged400sbc, All
#4, all of the above is correct.
Schlim: Your comments are a welome change. I've been hoping your new situation would not keep you too busy to check in.
Quote: ......... with camshaft duration and lift specs the same a high ratio rocker will accelerate the valve off the seat faster and close it faster though the ramp profile of the cam remains the same, if I am remembering correctly this increases the area "under the curve" which has a similar effect to increasing a cams duration...to a point. valve lift (total)is increased at every point of the lobe profile but the valve opening faster and closing faster (one reason stiffer springs are recomended-to control valve bounce/float which would occur at a lower rpm than with stock rockers) ......... Correct. Higher lift will contribute little or nothing without porting, and the area "under the curve" might make measureable gains. How much would depend, in part, on the flow characteristics of the head in question. Shorter pushrods to correct the geometry change should also be included, along with springs, in the kit. Quote: most ECM's have a certain range of value's that it is adaptable so a lifter install will give you more power but for the best power computer/tunning modifications will be necessary as with any internal combustion engine.......... I believe you meant rocker install. As I stated before, I believe the factory limits to be tighter than you describe in order to conform to emissions standards, but your statement is valid, regardless of what the tolerances might be. Quote: .......... is one of the reasons that a higher ratio rocker increases performance-more air+more fuel = more power......... In theory, yes. As I stated before, the actual gain is limited by the amount of air that actually enters the cylinder/combustion chamber in the specific application. Quote: .......... I am wondering if DrJay just might be confusing a couple of things regarding higher ratio (numerically) rocker arms.........
From what I read on his website and from all his posts, he has been quoting statements he read on the internet regarding series II engines, and he has little knowledge of the basics.
In the case of the series I, there are no published figures showing any gains from hi lift rockers only.
If there were, DrJay would have posted the link.
Has anyone wondered why manufacturers such as this one, are producing kits for the series II, but not for the series I?
Has anyone wondered why I keep posting this link?
Turbocharged400sbc
 Posted: Sun Jun 19, 2005 11:40 am |
yeah I screwed up I meant rocker....
yeah I have checked that link thoughly I have been in comunication with a gentlman in Australia (screen name locksmiff) Darryl who is the only other person I have found that is also working on a SII/SI hybrid with the SII cam and heads on the tall deck SI block....
Street commodore magazine has a forum (run search as I dont have a link handy...good guy so far we have been able to determin that it is doable but there still needs work as the pushrod angle seems to be offset a little (lifter bore spacing and locations are identical between the two blocks. the pushrods look like they do on the canted valve BBC heads it looks like the angle will be fine it would jkust be smart to get high quality pushrods when ordering the custom length.
I will keep in touch...
by the way we broke the rear window on the 442 just 30 minutes ago...we got 75% of the urethane cut and boom it shattered, but we have a new one as the orig was weld spattered, now we are starting to TIG the cage in....
James and AL
 Posted: Sun Jun 19, 2005 6:44 pm |
Hi Turbocharged400sbc, All,
88 Coupe wrote: DrJay wrote: You mentioned having a "computer car" as being an issue but that still doesn't make sense. Higher lift will pull more air, the MAF sensor will detect it and add the correct amount of fuel. In theory, yes. In abbike18s case, other factors such as compression and port flow, would limit the amount of mixture to the cylinder/combustion chamber. To follow your theory, the CPU would then keep mixture and timing adjustments within factory limits. If, in his case, an aftermarket chip is not needed, this paragraph is academic. Thanks for including paragraph three of DrJays first post. Your answer was for all, while my answer was to one who was familiar with the subject. Quote: ........... yeah I have checked that link ........... It looks like DrJay is the only one that knows why I posted that particular link. Quote: ............. I will keep in touch ............
Always ready for updates on your engine work.
 Posted: Sun Jun 19, 2005 7:46 pm |
Hi All,
Statement #2
DrJay wrote: ........... I don't have a before and after dyno for the ones I sell simply because I don't have a stock 3.8 to test them on.......... Or, maybe the product does not yet exist? DrJay wrote: ............ While I use them on my engine, using my before and after numbers would be a little unfair and the results would be useless as compared to a near stock engine.......... If they do exist, and are being used on DrJays engine, his dyno numbers would be a lot more useful than these, which I will deal with later. DrJay wrote: .......... On the other hand the SII rockers have been around for ages with dyno proof of gains...........
Again, a smokescreen to make us believe series II specs are valid in a series I discussion.
My reference sources:
http://www.seriesoneperformance.com
and, of course, Rocker arms for 1991 3.8.
Hans
 Posted: Sun Jun 19, 2005 9:59 pm |
ROFL
Please explain why DYNO gains on L36 motors are not a valid point of discussion.
Another thing, I try not to endorse any online vendor of automotive parts. Only reason I posted the link of the vendor's store was to indicate that there was an option out there for the orignal poster.
The price of the product in question is quite reasonable compared to what a similar product would cost for a very similar engine.
Quote: The 1.90:1 INTENSEâ„¢ Full Roller Rocker Arms are a complete bolt-on kit that should increase top end power by at least 20 to 25 wheel horsepower on a supercharged vehicle and 10-15 wheel horsepower on a naturally aspirated vehicle - depending on what other modifications have been performed. Click here for our first dyno session with Third Gen's showing a net gain of 23 wheel horsepower (29 crank horsepower) with NO OTHER CHANGES on a mildly modded Bonneville SSEi.
Go normy go go, go normy go go
 Posted: Mon Jun 20, 2005 12:05 am |
HI All,
Hans wrote: Please explain why DYNO gains on L36 motors are not a valid point of discussion............ 88 Coupe wrote: DrJay wrote: http://www.intense-racing.com/8ball.html Hope this will do for now. If abbike18 had the same combo, it might. It is not only off topic, it looks like a diversion. 88 Coupe wrote: In theory, yes. In abbike18s case, other factors such as compression and port flow, would limit the amount of mixture to the cylinder/combustion chamber. 88 Coupe wrote: ............ How much would depend, in part, on the flow characteristics of the head in question. Different flow chacteristics. Hans wrote: .......... Only reason I posted the link of the vendor's store was to indicate that there was an option out there for the orignal poster. ........... Hans wrote: drjay.... did not know you had a 93 88 as well.. really looking forward to the NGK plugs.  It doesn't look that way, but we'll take your word for it. Hans wrote: The price of the product in question is quite reasonable compared to what a similar product would cost for a very similar engine. The superior product would be worth the extra money, but it is is off topic because it will not fit the series I. Hans wrote: intense-racing.com wrote: ............ depending on what other modifications have been performed ........... More smokescreen. Still no figures for a series I, because they do not exist. 88 Coupe wrote: DrJay wrote: http://www.intense-racing.com/8ball.html Hope this will do for now. If abbike18 had the same combo, it might. It is not only off topic, it looks like a diversion.
The URL that was posted dealt with a blown engine only, which made it misleading to the point of being an outright lie.
and, of course, Rocker arms for a 1991 3.8
Hans
 Posted: Mon Jun 20, 2005 12:15 am |
88 Coupe wrote: Different flow chacteristics.
Please explain.
