It is currently Sat Nov 07, 2026 2:44 pm
 Posted: Sun Jun 12, 2005 3:40 am |
Hi speedy266, All
This might help.
If we were to put a pot containing 1 gallon of water on a stove with a high flame under it, it would take at least several minutes reach 212. If we then turned off the heat and poured a gallon of 32* water in with it, we would be able to put a finger in the mixture in seconds without fear of being burnt. If we left the heat on, the difference would be minimal.
Is this what has been described?
Or we can leave the fire on and remove a small amount of the 212 water at a constant rate, then by adding enough 32 water to replace that which was lost we can maintain the 212 temp.
This is what I believe should happen.
Possibly a combination of the two?
 Posted: Tue Jun 14, 2005 12:34 am |
Hans wrote: ...........drilled is not a bad thing to do either, do 2 1/16th diam holes as well ..........
Still waiting for Hans to explain himself.
 Posted: Wed Jun 15, 2005 5:20 pm |
Hi speedy266, All,
Quote: this is about chemistry and physics and science related stuff now. Of how water equalizes, heats up, cools down......... It's how the cooling system is designed to work with these variables. Quote: ......... the thermostat is a cheap mechanical device. Not computer controlled, in the future it might be ........ When the thermostat is no longer up to the job, its function will be given over to the computer. Quote: ........With the engine rpms higher more will flow by it before it closes ..........
Once it begins to open, it should not close until well after the engine is shut off.
73Delta88
 Posted: Sun Jun 19, 2005 2:56 am |
speedy266 wrote: With the heater on full blast, do you think the thermostat would still be able to keep the engine temp around operating temp or would it be less?
it will take a little more time to get the engine up to normal operating temp with the heater on (if you're starting with a cold engine)... but if the stat is working properly it should have no problem maintaining normal operating temp, even if the heater is on.
 Posted: Sun Jun 19, 2005 3:10 am |
Hi speedy266, All
Quote: With the heater on full blast, do you think the thermostat would still be able to keep the engine temp around operating temp or would it be less?
In theory, if the stat is rated at 180, the system is supposed keep the temp at 180 and under normal condidtions it does. In hot weather with the stat fully open, temp can go way above 180 and in cold weather with it nearly closed, temp can stay well below 180, heater or no heater.
 Posted: Sun Jun 19, 2005 3:16 am |
Hi Speedy266, 73Delta88, All,
Quote: .......... it will take a little more time to get the engine up to normal operating temp ..........
That too.
Regrds, Norm
 Posted: Sun Jun 19, 2005 9:37 pm |
Hi speedy266, All,
Quote: Ok well on an astro the operating temp is like 195F as the thermostat is, with the heater one full blast, rear and front, when first turned on with cold coolant in the core temps will drop down 150F than once all the coolant has a chance to heat up it will stay at a temp of 160F or so, and with the heater on full blast it can probably only rise to 170F before the stat opens (needle moves down to 160F again. As discussed before, temps will vary according to those outside. Adding two heaters to the system will, in effect, add more area to the radiator and the engine will run cooler than it would have with the heaters off. Quote: In the ciera with the heater on full blast the change is minimal probably only notice a lower temp of about 5F. Heater isnt as powerful as the astros heater, if i keep my hand near the astro vent when on full blast it burns my hand, i guess its needed to keep that huge box warm in the winter.
Smaller heater doesn't add as much area to the radiator.
Numbers can also vary, depending whether coolant circulation is stopped when the heater is turned off.
73Delta88
 Posted: Sun Jun 19, 2005 11:00 pm |
88 Coupe wrote: Hi Speedy266, 73Delta88, All, Quote: .......... it will take a little more time to get the engine up to normal operating temp .......... That too.  Regrds, Norm
Am I wrong? I'm not sure what to make of you're "laughing" emoticon... Who or what are you laughing at?
 Posted: Mon Jun 20, 2005 1:50 am |
Hi 73Delta88, All,
Quote: ......... Who or what are you laughing at?..........
Not at you, at myself.
You were correct and you answered his question more accurately and in less space than I did. If you had been wrong, I would have explained why.
I guess I need to learn the correct use of emoticons.
73Delta88
 Posted: Mon Jun 20, 2005 6:13 am |
88 Coupe wrote: Hi 73Delta88, All, Quote: ......... Who or what are you laughing at?.......... Not at you, at myself. You were correct and you answered his question more accurately and in less space than I did. If you had been wrong, I would have explained why. I guess I need to learn the correct use of emoticons. Regards, Norm
I figured that's what you meant, but I had to be sure
As for the proper use if emoticons, I don't think there is one right way to use them, it's just that sometimes people interpret things differently.
ok, back to the thermostat conversation...
