It is currently Mon May 04, 2026 8:48 am
 Page 4 of 6 [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Jun 20, 2005 1:34 am
Hi All,
Hans wrote:
Please explain.
Basic flow chacteristics=The amount and velocity of the air that can flow through the intake and exhaust ports of a given head, as measured on a flowbench.
http://www.jhsracing.co.uk/common/super ... _bench.htm
PostPosted: Sun Jun 26, 2005 11:25 pm
Hi All,
I’m going to start from the beginning and work my way to the end of this entire post. Not all at once.
First post, fourth paragraph:
DrJay wrote:
You also mentioned having a "combo" of ratios that decreased performance. I can only assume you mean between the cam lobe lift and rocker ratio.
DrJay wrote:
Your statement was a little confusing about "various combinations of ratio combinations" so I figured you were talking about a "combination" of a rocker ratio and a certain lobe lift. Such as X cam with Y rockers didn't work, but Y rockers with Z cam did.
The subject is Ratio rockers with a stock cam. A cam change would be another subject. When I do not understand a statement, I ask for clarification before responding.
DrJay wrote:
That's always a good habit……….
Depending on who he might be dealing with?
DrJay wrote:
I didn't think this thread would get carried away,
Didn’t even consider the possibility he has been misinformed?
DrJay wrote:
so I took a stab at what I thought you may have been talking about.
No comment.
DrJay wrote:
………. a roller tip is always a good bet.
Not for $565.00.
Reference sources:
http://www.seriesoneperformance.com
http://www.yellaterra.com.au/index.php
and, of course, Rocker arms for 1991 3.8.
PostPosted: Wed Jun 29, 2005 10:26 pm
I am still of the opinion that the gains that you will get from this swap will not justify the time or the money spent on it. Why not just use SII heads and be done with it? I guess I dont know if they fit or not or if it is even able to be swapped, but it seems as if alot of time, energy and effort could be saved by doing that instead if changing the rocker ratio. Just my opinion, and I think I read this in this thread somewhere, but isn't chainging the rocker ratio without doing anything else just a band-aid for not doing a cam swap? But I am not an expert on the 3.1 "performance" stuff, and I have not doen any research prior to posting this, so idk if the SII heads will go on the SI block and work or not, just an idea.
PostPosted: Thu Jun 30, 2005 4:31 am
Hi andrewk, All
That is a fact, and it has been my point from the beginning. Even assuming the bogus figures to be correct, the return is not worth the expense.
The rocker arm salesman has an investment to protect. He cannot admit his knowledge is internet style misinformation for fear of losing his (self appointed) status as an expert/authority.
Why not just use SII heads and be done with it? ........
You cannot get any more basic than, "The heads are where the power is".
Head configuration is the only significant difference between the "air pumps" from different manufacturers, and between series I and II engines.
If DrJay were to sell a well designed aftermarket head for his engine, I would endorse it.
......... isn't changing the rocker ratio without doing anything else just a band-aid for not doing a cam swap?...........
DrJay wrote:
Besides, many people enjoy the ease of installation and gains received from rockers. Of course a camshaft is a better solution, but not everyone is willing to dig that deep in their engine so for them this is a good alternative.
Unless I missed one, “Of course a camshaft is a better solutionâ€
PostPosted: Thu Jun 30, 2005 8:48 pm
PostPosted: Fri Jul 01, 2005 8:31 pm
Hi Turbocharged400sbc, Norm, All,
So if you can in fact put SII heads on a SI engine, then why would anyone even mess with the SI stuff? Considering all the performance parts available for the SII, it seems to me that trying to tune the SI's, whether it's valves, rocker ratio, whatever, is a big waste of time and even more so a poor business investment. If you are willing to piss around with valve train geometry on the SI heads, then why not invest your time in the SII conversion and then work on different rocker ratios for that. I think Dr. Jay may be over thinking in this situation. I think maybe if he was thinking more outside the box that he might realize that the benefits of what Turbocharged400sbc is doing are far better than what he is trying to accomplish. I am not sure, however, if I have missed the point of this thread; are we discussing the theory of valve train geometry, such as it increasing duration, etc., or are we discussing the potential benefits of a geometry change on SI heads?
Oh, and I typed 3.1 in my last post. I meant 3800, but I am sure you all knew that.
PostPosted: Sat Jul 02, 2005 12:30 am
Hi Turbocharged400sbc, All,
.......... it's all about the modern redneck engineered hotrodding! .........
Basic Hot Rodding, the way it was done in the 20s. Some time between then and now, knowledge and ingenuity were tossed aside in favor of assembling aftermarket parts.
........ just not as easy as swapping fuelie heads onto a 327.......
Ah, the legendary FI heads. Great "WOW" factor from the double humped heads when the hood was raised. Out of the box they didn't make much of a difference. Later, renamed "fuelie" by the "car rags" because it looked cool on the front pages.
I did better with selected "Power Pack" heads, but I didn't just bolt them on.
...... alot of missinformation out there .........
More than most people realize, a lot more.
PostPosted: Sat Jul 02, 2005 3:41 am
Hi andrewk, All
I think Dr. Jay may be over thinking in this situation. I think maybe if he was thinking more outside the box that he might realize that the benefits of what Turbocharged400sbc is doing are far better than what he is trying to accomplish .........
I think you over estimate DrJay and his knowledge of the basics.
His last two posts should have given you some insight.
Hans/DrJay wrote:
Please explain why DYNO gains on L36 motors are not a valid point of discussion............
Different flow chacteristics.
Hans/DrJay wrote:
Please explain.
The company that will manufacture his rockers (after he sells them) did not choose to make them part of their own line.
What do they know that he does not?
........ I am not sure, however, if I have missed the point of this thread; are we discussing the theory of valve train geometry, such as it increasing duration, etc., or are we discussing the potential benefits of a geometry change on SI heads? ..........
Actually the question that was asked in the first post, was answered in the second. From Hans first post on, it has been about internet misinformation and unethical sales practices.
I've seen little discussion. Basically, there has been DrJays theories, and everyone elses statements of fact.
...........I meant 3800, but I am sure you all knew that.
I didn't notice, probably because you were not talking cubic inches.
Reference sources:
http://auto.howstuffworks.com/engine.htm
PostPosted: Sat Jul 02, 2005 5:32 am
Hi andrewk, All,
......... it seems to me that trying to tune the SI's, whether it's valves, rocker ratio, whatever, is a big waste of time and even more so a poor business investment. If you are willing to piss around with valve train geometry on the SI heads, then why not invest your time in the SII conversion .........
Bingo!!!!! :) That's where the power is.
......... and then work on different rocker ratios for that .........
No help unless the cam is ground to work with that ratio. So you grind a profile that needs special rockers in order for it to work properly? I don't think so.
PostPosted: Sat Jul 02, 2005 9:54 am
Hi andrewk, All,
as I have found out through StreetCommodores.com there is a gentlman who took the SI (Buick) heads and had the valve guids spread to install valves of (real close) aproximate size to the factory valves in the SII heads with the guid work and valves seat machining he had (if I remember correctly) 2100$ AU invested in the mod and he got flow #'s slightly better than the factory (with mild bowl porting) SII head on the intake but equivalent on the exhaust (he didnt have a bone stock SII head to flow test at the time) he ended up with rockers that now pushed on approx 80% of the valve stem tip where as before it was dead center, now a small amount like that wouldnt hurt things and it looks like this will be something to look for on the SII heads onto the buick block (though lifter bore spacing remains the same (as much as a dial caliper is acurate from one block to the other so the factory prob moved the rocker pedestal a slight amount to counter the wider vlv guide spacing on the SII
all are are's I need to cover in my Hybrid buildup...but the point remains that there are people who spend cubic $'s on performance of the SI, and in the end it's one thing that most of us are looking for-BANG fer the BUCK!
a 500+$ set of rockers that add 10-30(?) HP versus a custom SI cam (available in OZ btw) at 350$ that would be better suited to making 30+ Hp with proper ECM tunning
but then again some people are hesitant to tear into their engines so for some people rockers may be a great deal....
I will try to find all the info I had saved on my puter in Han(g)over Park (right now I'm at my shop in Rockford) and see if i can find his flow data for his seriously reworked SI heads and the mild SII heads...
plenty of info on the SII heads at 3800pro.com (Intense racing board) but for the SI info ya gotta check out the auzzie's sites...
also some great info is on FTV6 -FullThrottleV6.com-
you can check out the custom sheet alum dual TB intakes those guys have made for the SI!
lowbuck hotrodding! (we rednecks dont have $ so we have to get by on a moonshine budget...)
case in point...instead of dumping 2-3 grand into the 3100 in Al's car we doubled the power by adding another engine fer 3 grand (so far lol)
James...
Btw I dont think Jay is belittling my work, as alot of people dont understand why I would be working on this ("just throw in an L67") but with PCM/trans/harnesss that $$$ adds up to allot more than I think I can put the hybrid together for...
as in most cases throwing money at a car doesnt make it faster (remember the prostreet trend in the late 80's early 90's HotRod (?) had a prostreet race and found out how slow some of those 80+ thousand dollar cars were...) you have to look at the whole package for max power, you change gearing, you end up having to change the Tq converter and cam to make the best use of the engine's power band...
PostPosted: Sat Jul 02, 2005 10:01 am
but when tunning an engine combination different ratio rockers can be tested to determine whether the engine could use more valve lift to make more power...
and with mechanical flat tappets (i know doesnt apply here but to make a point) same way that tuners will change (test different) the lash specs to determin if the engine requires more/less duration for powerband tunning...
remember it is average power/Tq #'s that make a car fast/consistent where most manufactures like to give peak #'s that dont tell you squat!
PostPosted: Sun Jul 03, 2005 2:53 am
Remember: Since post #5, the entire thread has been about a rocker that does not exist, and there are no valid numbers to quote.
……… but then again some people are hesitant to tear into their engines so for some people rockers may be a great deal...........
In the same way some people use a fart can on their exhaust to increase power? There can be a power gain with either, but is it worth the cost?
For return on ones investment, the fart can might be the better deal. It's up to the individual, it's their car, time, and money.
Efficiency is achieved by selecting a group of modifications that will work in unison. Not by adding parts at random and then throwing them aside when moving to the next mod.
yellaterra.com.au/faq.php wrote:
10 – Should I run a higher than standard rocker ratio?
Many cam grinders today specify rocker ratios higher than standard for specific camshaft grinds but in most cases, unless specified, the standard ratio gives you the best results.
This is a company that manufactures and sells both.
I would suggest one save his/her money until the cash is available to do it right. During that time a plan can be made to maximize the "bang for the buck".
Btw I don’t think Jay is belittling my work .........
DrJay wrote:
……. although for the average person the effort involved for the nominal gains would be prohibitive.........
Please excuse the bold font, but it appears I need them to make my point.
Nominal:
In this context, can anyone find a definition other than "small or nonexistent"?
.......... a lot of people don’t understand why I would be working on this ……..
They are the same people who believe assembling a bunch of aftermarket parts will result in a race engine.
Once Turbocharged400sbc proves his work to be viable and posts the road map, it can be duplicated (porting excluded) by any competent shop at a reasonable price. The R&D is the expensive part and it will have already been done.
…….. as in most cases throwing money at a car doesn’t make it faster (remember the prostreet trend in the late 80's early 90's Hotrod (?) had a prostreet race and found out how slow some of those 80+ thousand dollar cars were .........
The builders of those cars intended them to be showcars only and the articles were intended to increase circulation in the teenage population.
Since the early sixties, the rags have been geared toward those who do not know the difference between a street car, a race car and a show car. They are most likely to buy the advertised parts that the knowledgeable will not, and advertising is where the profit is.
BTW: They are the same group DrJay is trying to reach.
……... but when tuning an engine combination different ratio rockers can be tested to determine whether the engine could use more valve lift to make more power……..
How many diferent sets at $400 each? Easier, cheaper, and many more times accurate to give the pertinent information to the cam grinder, and get the correct one in the first place.
........ with mechanical flat tappets (i know doesn’t apply here but to make a point) same way that tuners will change (test different) the lash specs to determine if the engine requires more/less duration for power band tuning ……..
You're right, it doesn't apply, unless you're doing a DrJay impression.
As valuable a tool in the 40s as it is now. The difference is the control of small amounts of lift and duration, as opposed to a hard choice between two very different lifts with no duration change.
The former is used daily as a tuning aid. The latter?
The portions of your posts pertaining to your projects, should be posted in your threads where they are more likely to to contribute to the readers education on those subjects.
I, for one, prefer to read them there, in their proper context, because here they confuse the issues even more than they are. Much like DrJays diversions.
Reference sources:
PostPosted: Thu Jul 07, 2005 10:45 am
Hi All,
DrJay wrote:
I don't have a before and after dyno for the ones I sell simply because I don't have a stock 3.8 to test them on. While I use them on my engine, using my before and after numbers would be a little unfair and the results would be useless as compared to a near stock engine.
So DrJay has something that cannot be compared to a near stock engine?
I think I said somewhere else: His would be more useful than numbers from an already modified Supercharged SSEi.
DrJay wrote:
I built a S1 that in many respects is the first of its kind.
If I “builtâ€
PostPosted: Thu Jul 07, 2005 6:43 pm
wow....this could get good.... Pass the popcorn please!
PostPosted: Sat Jul 16, 2005 5:51 am
Hi All,
It seems DrJays SI rockers do exist, and they are available in the US and Canada, through several distributors.
Look here for Holden/Buick V6.
Any guesses why his refusal to post the link, and why he needed to explain everything to us instead?
How can they be on so many engines and no one wants to give up any numbers?
DrJay wrote:
In performance and racing builds, they can.
How about if I took all of the EVO IVO IVC and EVC events and put them at random...Would that affect performance in a stock engine? Or did I jump the gun on another typo?
A little frustrated because I don't go where wants me to?
Alternative thought might be that he realized he is in over his head.
DrJay wrote:
And your point?
My point was simply that, I haven't seen it. There are a lot of things each of us haven't seen, that's one for me. I think it would explain my disbelief in higher lift resulting in less power.
Since he hadn’t seen it, he disbelieved it?
DrJay wrote:
Does the reduced friction of the roller tip compensate for the increased friction caused by the extra lift and the resulting incorrect valve train geometry?
It's possible, but I don't have the necessary numbers on hand.
Interesting answer. Actually it's the opposite. Increased lift does not increase friction per say. The roller tip decreases side loading on the guide and reduces friction. Another hint that he hasn’t a clue.
DrJay wrote:
If abbike18 had the same combo, it might. It is not only off topic, it looks like a diversion.
You asked for dyno proof and while I don't have any for these particular ones I was providing proof that rockers can add performance to a "cpu" controlled 3800.
I think it would have worked better as a diversion if I didn't directly respond to each of your statements following it.
He didn’t think anyone would notice the link was to a blown SII application? He didn’t think we would know the difference?
As we now know, it was he that didn’t know the difference.
DrJay wrote:
And you get a power increase of more than 10%?
More than 10% from a performance camshaft? Sure.
Varies with the engine, and since he has no numbers, it’s just more smoke.
DrJay wrote:
Ease of installation and less expense is always a good selling point, but it is off the subject.
Yeah that would make for a good selling point. It's a wonder why I don't (and never will) include that in the part description...That was merely to address your statement about rockers being a band-aid for a "poor cam choice." Since it was a response to a statement you made I can only assume it was on topic.
Salesman’s logic shows that ease of installation and less expense is why the rockers make the gains he claimed?
DrJay wrote:
Reduced friction is always good, but in this case, roller tips alone are not worth the time and expense.
You're right, but luckily I'm also offering the entire higher lift rockers with the tips.
Since this is the company that manufactures and sells both, I'll believe them.
DrJay wrote:
Since it was a fresh build, they replaced nothing. What is your point?
I try to make my points clear. If reduced friction was not of any benefit at all why would GM spend the time and money adding them to the '93? I can only assume they did it for a reason and not just because an engineer was bored and decided to try something new on a production car.
I guess he didn’t understand the concept of a factory redesign vs replacement of worn rockers vs needless replacement of good ones.
DrJay wrote:
I am familiar with the theory. We are all still waiting for real world numbers.
So am I. If you ever find yourself owning a 3800 and decide to buy the rockers feel free to dyno test and report.
So now he wants me to prove his flawed theory to be fact. First his false statement about cam duration. now this.
DrJay wrote:
It explains the theory behind the estimate, while avoiding the subject.
You seemed to take issue with the 8-10% remark. I don't understand how my responding to that is "avoiding the subject."
Theory is not fact until it's proven. Your 8-10% remark was made with nothing to back it up.
DrJay wrote:
You can choose to believe a salesman, or someone with hands on experience. It’s your money and time.
I think it's extremely rude to imply that I'm some sleazy salesman here to spit a line and make a buck. I don't do this for profit, never have. I don't expect you to believe that but many of the people who actually know me can attest to that.
Methinks the salesman doth protest to much. :lol:
DrJay wrote:
But I doubt you'll ever talk to one of them and will probably continue to pass judgment based on your own assumptions.
Correction: Based on what DrJay has written in his web site, this and other forums. In his own words.
DrJay wrote:
You also presume to know how much "hands on" I have with these engines, yet call me rude?
I believe someone with hands on, would be more than a match for me in the context of this thread, and one with an internet education would only be able to debate theory. He called me rude because he disagreed with me. I called him rude because he was rude.
DrJay wrote:
Let me elaborate a little on an earlier statement. I'm not here to make money and chances are I never will be. I built my 3800 from the block up and had to do months of research into every piece because nobody carried them. There isn't a single company out there that carries a full line of performance parts for these engines, and I thought that just flat out sucked. So once I was done loading my engine with every piece I could find, I decided to make a webpage to help others find them. I'd like to make it a one-stop-shop for the neglected S1 3800 and that's all. MOST of the parts there I barely make enough on to make it worth driving to FedEx and that's the honest truth. I do it because I like it. I enjoy helping people get the OEM parts they need, I enjoy being able to provide performance parts, and I really enjoy being able to breath a bit of life into the performance S1 3800 community.
Why does this sound like another sales pitch? Those parts are all available at any competent shop or parts supplier, but I guess DrJay doesn't know that because he only shops the internet.
DrJay wrote:
…….. So once I was done loading my engine with every piece I could find …….
Now, that’s funny. I think he covered it nicely. Here also.
DrJay wrote:
I didn't come here to convince anyone to buy the rockers.
More like, to put some teenage kid down because he didn't believe your bogus advertising and it looked like he might convince a possible buyer not to buy?
DrJay wrote:
I thought it would make for an interesting discusson and maybe we can both learn something.
If one side does not know the subject as it relates to the thread, there will never be a discussion.
It frustrates a salesman when he cannot be the authority and take charge of a conversation.
DrJay wrote:
Matter a fact we did. I learned some people take bold text regardless of placement as offensive,
Rude is rude. A good salesman makes his living by being rude and intrusive. I am one who doesn't like salespeople for that reason.
….. and as soon as you look into it you'll learn that higher ratio rockers have a slight affect on duration.........
Just one of many examples of the misinformation found daily on the internet. Duration cannot be changed unless the lobe profile is changed.
This guy was wrong also. Surprised me because he is more knowledgeable than most on that forum.
DrJay wrote:
……..But it came at the expense of attempted degradation, so it doesn't seem worth it ………
The statement was false when he made it and it’s still false. Degradation? When one is wrong, one should expect to hear about it. It’s called being an adult.
DrJay wrote:
Again though, I don't expect you to believe that. I probably wouldn't if I was sitting where you are. But at least I can say it and know to myself that it's the truth.
The truth as he knows it.
I am suspicious of everything I see and hear until I can verify it as fact or fiction. When statements are made that I know to be false, I usually react the same as I have here.
Reference sources:
http://bonnevilleclub.com/forum
http://www.3800tech.com/forum
