It is currently Wed Nov 11, 2026 11:19 pm
 Posted: Tue Jul 19, 2005 3:37 pm |
Hi All,
DrJay wrote: I'm sorry I haven't answered the questions to your satisfaction. If anyone else reading this feels that I have "danced around the facts" and tried to use "diversions" please let me know how and I'll try to give a more detailed answer.
For the record I don't deny being a "salesman" because I am a man and do sell things. But I'm not here to make up stories just to push a product, which is what you were insinuating.
I hope through all this mess abbike18 is able to get some kind of answer to his question. If you want any more details about the product feel free to email me. Already covered. DrJay wrote: 88 coupe: If you need some web sites about the technical side of rockers let me know, I've got a few that may interest you. Anybody understand this one? DrJay wrote: The rocker manufacturer isn't going to have anything more about the product openly available. They're not geared towards the public so there isn't a flashy webpage with a ton of information on it. I've personally asked about most of the information you see there and can relay any further questions you have. http://www.yellaterra.com.au/application.php?page=app7 Looks like exactly what I requested. Anyone need a salesman to translate? DrJay wrote: Again, not sure where I've faked it. Given the chance you decided not to quote me and point it out. If you have a question about ANY portion of what I've said please feel free to quote it. The only one you did is easily explained here: Quote: I don't have a before and after dyno for the ones I sell simply because I don't have a stock 3.8 to test them on. Quote: Dyno numbers would be a welcome addition to this discussion. Quote: http://www.intense-racing.com/8ball.html Hope this will do for now. I said I don't have dyno numbers, you still asked for dyno numbers, so I gave you the best thing I could find. It's a newer 3800 with a "cpu" (as you like to call it) that saw gains from similar rockers. I understand you would like to see dyno charts of these rockers on this engine, as would I, but to call it a diversion is a bit overboard. Besides, you aparently didn't believe me from the start so what would putting up some dyno chart do for you? Think you would believe it? To answer the question I did not ask, is a diversion from those I did ask. DrJay wrote: Quote: Maybe, you need to stay closer to subjects you know, so you can actually answer the questions instead of faking it.
It's strange you would say this especially considering I'm the only one between us that actually has a S1 3800 AND these rockers on it. Top that off with the fact that you didn't even know higher ratio rockers add a slight bit of duration and I have to wonder who that comment should have been directed towards. Already covered. DrJay wrote: Quote: Since you ignored it the first time, here's another chance to explain this one. It is your best example. If you miss anything, I'll fill it in for you. I'm not sure what needs explaining there. I said if you need me to elaborate on something I've said let me know. An example of this would be if you quoted my explanation of the 8-10% and asked a direct question about it. 88 Coupe wrote: In theory, yes. In abbike18s case, other factors such as compression and port flow, would limit the amount of mixture to the cylinder/combustion chamber. No questions needed. As a theory it might be valid. In practice the numbers aren't there. I thought thats what I said. Quote: No one said you make up stories. You just do not have enough correct information to support your opinion. My guess is: your automotive education was on the internet and the streets. Actually it looks to be all internet, and nothing from the streets. DrJay wrote: So I "fake it" yet don't make up stories...not sure where you're heading with that one, but ok. Faking (or bluffing) ones way through a conversation, as opposed to, making up a story to start it. DrJay wrote: I'm not going to go through and list my education to you, but my personal experience with the 3800 is well known to many people. I built a S1 that in many respects is the first of its kind, but I'm also not here to beat my own drum so I'll leave you to investigate that.
I still don't know what I should investigate, but I did find this. It's the story of how a “hands onâ€
 Posted: Mon Aug 08, 2005 10:54 pm |
 Posted: Sat Aug 20, 2005 3:57 pm |
Hi andrewk, All,
Still working on my response to the post I missed. Right now it's 8 pages in MS Word. Hopefully it will be shorter and thankfully it will be my last.
Meanwhile, I thought I'd explain DrJays joke.
Starting with my reference to "significant gains from ratio rockers".
DrJay wrote: 88 Coupe wrote: In performance and racing builds, they can. How about if I took all of the EVO IVO IVC and EVC events and put them at random...Would that affect performance in a stock engine? Or did I jump the gun on another typo?
Those four events are cam specs. They represent both valves opening and closing points and are expressed in crankshaft degrees as found on the "cam card" that comes with the cam.
Using those specs to check the camshaft relationship to the crankshaft is called "degreeing the cam". Lift can be checked at the same time.
His questions are another diversion. They do not make sense and do not relate to my statement, or anything in the entire thread.
Poor substitute for a question/comment. Maybe it was a typo. Can you say, faking it?
 I guess Hans didn't bother to tell him I was degreeing cams before he was born.
 Posted: Tue Aug 30, 2005 7:12 pm |
That is almost verbatum what I said a few pages back.... But we are still awaiting Dr. Jays "triumphant" return to the board so he can claim his second place prize.
 Posted: Tue Aug 30, 2005 7:28 pm |
Hi ahondadriversnightmare, All,
Quote: why would you do all that work to that series 1...all the work you can do to it would get you little gains ........ Please define "all that work" and how "little gains"are the result. Quote: .......... better off spending the cash for more over all power..like getting a series II SC...thats like 235 or more horses .........
The reason I wouldn't:
No challenge involved, any "cool aid drinker" can do it.
Better bragging rights if one built a Series 1 to "like 235 or more horses", without the blower.
Turbocharged400sbc is using blowers to make more power than I would. I expect, he will be here shortly, to tell you about his "little gains".
 Posted: Tue Aug 30, 2005 7:48 pm |
Hi andrewk, ahondadriversnightmare, All,
Quote: That is almost verbatum what I said a few pages back ........
Easier to adapt the S2 head than to port the S1 to the same numbers, but how much is left untapped in the S1 head?
James and I have different philosophies. I would use the S1 head, as it would present more of a challenge.
1 HP per cubic inch in an engine that small seems like a piece of cake.
But what do I know?
 Posted: Tue Aug 30, 2005 8:17 pm |
Hi Norm, All,
I think I understand where you are going with that. The debate was about the sole benefits of a rocker change without a cam swap, and how this rocker change supposedly increases lift and duration enough to make it worth the time. So the S1-S2 debate is not what was initially discussed, right? I kind of like your point about what is left untapped in the S1 head. Since the dimensions are essientally the same, what are the changes to the S2 from the S1, and what can be done to the S1? And would the time and mone spent in the custom S1 head job be worth it? With the availability of good aftermarket parts, can the S2 be made to out perform the total potential capability of the S1? I know you are a fan of using factory stuff to its fullest potential, and I think that it would make a more impressive build if one were to use the S1 stuff, but only if the potential was there. I guess I should research the differences in the S1 head and maybe Ill come up with some thing. This is kinda random, but I am just throwing some ideas out there.
 Posted: Wed Aug 31, 2005 4:42 am |
Hi andrewk, All,
Quote: I think I understand where you are going with that ........ Not going very far. Unless the right car becomes available, my input is academic. Quote: ........ The debate was about the sole benefits of a rocker change without a cam swap, and how this rocker change supposedly increases lift and duration enough to make it worth the time. So the S1-S2 debate is not what was initially discussed, right? ........ Was there a debate? Since DrJay’s bogus figures were based on his presumption that both heads flow the same, discussing the differences and where the power actually is, should be on topic. Quote: ........ what are the changes to the S2 from the S1, and what can be done to the S1? ........ S2 head was cast with bigger ports and machined for bigger valves. Any mods applied to one should work on the other. Quote: ........ would the time and money spent in the custom S1 head job be worth it? ........ Depends who does the work. All head guys are not created equal. If all you want is the most power, use the S2 going in. Quote: ........ With the availability of good aftermarket parts, can the S2 be made to out perform the total potential capability of the S1? ........ Everything being equal, the S2 will always outperform the S1. S2 heads on the S1 might do better. James will tell us when he finds out. Quote: ........ I know you are a fan of using factory stuff to its fullest potential, and I think that it would make a more impressive build if one were to use the S1 stuff, but only if the potential was there........ I use OEM stuff as long as it does the job. Common practice is to buy aftermarket parts that are not needed. Quote: ........ I guess I should research the differences in the S1 head and maybe Ill come up with some thing ........
Don't forget to check this link.
strokercutlass
 Posted: Mon Oct 03, 2005 10:57 pm |
| TOC Mechanic |
Ok...I can see I've been away far too long...AGAIN!!! Norm...as always, you've been busy keeping everyone on the straight and narrow, and although I'm sure you and Andrew have both covered this, I just want to refresh a few points....
1. Without comparative dyno testing on SIMILAR engines, how can it be said that these aftermarket rockers can in fact improve performance at ALL? It's pure speculation, as making based comparisons of rocker arm geometry gains between non similar engines is utterly ridiculous due to the fact of different intake and exhaust flow characteristics, camshaft profiles, and the like.
Sure they may reduce friction, which is always a good thing in ANY combustion engine, but without comparable testing the claim of even slight gains is mute and irrelevant.
2. This quote really got me.....
Besides, many people enjoy the ease of installation and gains received from rockers. Of course a camshaft is a better solution, but not everyone is willing to dig that deep in their engine so for them this is a good alternative.
Well SUUUUREEE...I just LOVE nothing more than going thru and tearing down the upper end of my engine to install replacement parts that will offer no significant gains in performance, yet give me the bragging rights of having "updated performance rockers" on my engine....
" So man....what's under the hood???"
"Series 1 3800 engine"
"Looks stock."
"Ahhhh...thats just what I WANT you to think.....honestly I have a set of "High performance aftermarket roller tipped rocker arms" that I installed that gained me at least 8-10% more HP and torque over stock.....pretty sneaky, huh?"
"OHHHHHHHHH.....nevermind.....I was gonna race you, but obviously due to those high perf rocker arms you enjoyed the ease of installing, I's SURELY get my azz whooped....I'll spread the word not to mess with you!!!!"
HAHAHAHAHA!!!!!
 Posted: Tue Oct 04, 2005 8:33 am |
Turbocharged400sbc
 Posted: Tue Oct 04, 2005 10:25 am |
 Posted: Tue Oct 04, 2005 1:45 pm |
Hi Stroker, All,
Nice to see you back. It's been fun causing enough trouble for two. Did Hi-Speed catch up to you or did you find some extra time to exercise the dial up connection?
It's the itsy, bitsy, teeny, weeny, little bit of extra duration from those rockers that creates all the power.
I'm done
Don't be a stranger.
Turbocharged400sbc
 Posted: Tue Oct 04, 2005 2:13 pm |
88 Coupe wrote: It's the itsy, bitsy, teeny, weeny, little bit of extra duration from those rockers that creates all the power. I'm done  Regards, Norm
ummmm..not to  here but didnt we establish that duration at the valve is the same... it is the extra valve lift/faster opening/closing rate of the valve the "Lift under the curve" that changes and give a itsy, bitsy, teeny, weeny, yellow plokadot bikini...i mean extra power...lol
 Posted: Tue Oct 04, 2005 5:27 pm |
Hi James, All,
Quote: .......... didn't we establish that duration at the valve is the same ...........
It was established in the first post on the second page.
I thought it was, clearly, a parody on DrJays "little bit of duration" statement, and that it was outrageous enough that it didn't need a "smiley". I guess not.
Am I done yet?
