It is currently Sun Nov 08, 2026 11:09 pm
73Delta88
 Posted: Tue Oct 26, 2004 10:45 pm |
ahondadriversnightmare wrote: or u can just find a rotted out GN and yank the turboed 3.8 out and make the swap. there could be room for the intercooler on the rite side of the engine bay..maybe.
as was stated before not long ago, north / south engines don't like to be mounted transverse. I know those engines are completely different, they just both happen to displace 3.8 liters. It might be quite a project, if it's possible at all.
 Posted: Wed Oct 27, 2004 2:24 am |
Hi speedy266, OldsGuy, hello All
Quote: I saw an advertisement on the show Trucks for Compcams, Stacey was saying they were good............ Comp Cams is paying that production company a lot of money to showcase their product and that money pays his wages. If the script says it's a good product, thats what he says. Can you say Infomercial? Quote: .......So now im thinking of getting a cam, they offer 4 different ones.......... OEM means it is the same as you have, and 2, 3, and 4, each move the power band higher. Without the other mods that work in concert with the upgrades, the bigger grinds might even give you less power than you already have. Quote: .........Just lookin to get some more info about cams...... Go to Oldspower.com, find the Front Drive section, post your questions and you should get answers that pertain to your needs. In the meantime This might give you an idea how involved cam dynamics are. Keep in mind they are only touching the basics. Quote: ........Im planning on supercharging it in the future so would that effect which cam i buy?........ Supercharged engines use cams designed for that purpose. NOS is a lot less expensive and will not blow the bottom end out of your block as quick. Quote: .......Anybody replace there cam with an aftermarket one?....... A couple of times
strokercutlass
 Posted: Fri Oct 29, 2004 9:11 pm |
| TOC Mechanic |
Speedy, unfortunetly those cams are designed for a RWD application, and not a FWD like you have. They made even and odd fire versions of the 3.8 liter RWD engines, and the 3.8 encompassed both the 231 V6 RWD Buick engines as well as the 229 Chevy V6 RWD versions, depending on application.
 Posted: Fri Oct 29, 2004 9:38 pm |
strokercutlass wrote: Speedy, unfortunetly those cams are designed for a RWD application, and not a FWD like you have. They made even and odd fire versions of the 3.8 liter RWD engines, and the 3.8 encompassed both the 231 V6 RWD Buick engines as well as the 229 Chevy V6 RWD versions, depending on application.
That's what I was kinda hinting in my previous post....thought it was for RWD...glad that you could clarify it.
