It is currently Mon Nov 09, 2026 3:00 am
 Page 1 of 1 [ 13 posts ]
 Post subject: 4 bbl on a L6
PostPosted: Fri Mar 11, 2005 9:48 pm
I have seen a special intake for an inline 6 so you can mount a 4 barrel carb on it, what are your guys' opinions on this?
Heres a link http://www.jcwhitney.com/autoparts/Item ... 8420363700
Josh Egeberg
CCC
PostPosted: Sat Mar 12, 2005 12:04 am
Why would you need a 4 barel car b on a Chevy stovebolt six? thats usually used with a small 4 bbl carb (<450cfm) unless you have a heavily built up L6 a 2 barrel carb will give you better throttle response and bottom end Tq, which is what the inline six was designed for.
So what ya working on? a vintage Bonnevile racer?
PostPosted: Sat Mar 12, 2005 1:13 am
Hi c_creations, Turbocharged400sbc, hello all
........... a Chevy stovebolt six ........... a heavily built up L6 .........
The manifold at the other end of the link will not fit a "stovebolt", and as far as I know Chevrolet never produced an "L head" anything.
You could say that "Add V8 power to your in-line 6-cylinder engine" is a bit of an exaggeration. :lol:
PostPosted: Sat Mar 12, 2005 1:24 am
L6 was supposed to be IL6-sorry
1962 IL6 i thought were the stovebolt 6's but maybe it is the 40's iL6 that is-been a while since i talked with my Gramps...
my bad
James
 Post subject: Re: 4 bbl on a L6
PostPosted: Sat Mar 12, 2005 2:36 am
Hi c_creations, all
............ what are your guys' opinions on this? ............ Heres a link ..........
[url=..... if you put the link in here ......]Here's a link[/url]
it will come out looking like this: Here's a link
Makes it so I don't have to scroll to find Turbocharged400sbc's quote button. :lol:
Turbocharged400sbc:
Appologies are not appropriate in this case, I bring these things up because I believe you (and other TOC members) are interested in accurate communications.
If you had called it an inline (or straight) Six, I would not have confused it with other designs.
My guess is '52 was the last 216 incher. Although the next generation 235 did not use "Stovebolts" for fasteners, it did keep the nickname. '62 was a very different design based loosely on the SBC and was either 230 or 250 CID.
PostPosted: Sat Mar 12, 2005 3:08 am
lol i jus learned me sumthin new... how you always did tha handy link deal 88, thanks for the info! now i will have to try it sometime!
I have rebuilt (rings bearings etc-no overbore-farmers rebuild i guess) a 230/250 from a 68 chevy van (no bolts holding them dampners on lol!) I noticed that the rockers and head looked allot like the sbc (a bit heavier though!)
I know about the stovebolt cause my gramps sent me back here with a square head wrench set (some are stamped with sizes others arent) 7/16,9/16,5/8,11/16 the other couple i havent measured yet-just good memories of my gramps, he had them since his first toolbox. doubt they are antiques though.....
thanks for that link info!
you shoulda been here when i was giving brando a headache emailing him the video files of the twin V6 442!
James
PostPosted: Sat Mar 12, 2005 7:17 pm
Hi c_creations, all
Fixed....appears that IE wraps the link, but Firefox.....doesn't. :roll:
So, I added a little thingy for it to do so. :D
PostPosted: Sat Mar 12, 2005 7:57 pm
8)
PostPosted: Sat Mar 12, 2005 10:13 pm
hmm, well thanks for the link info, thats something that didnt know, it says it should fit on the IL6, its a '68 engine, i was just wonderingin. im just playing with this engine see what makes huge differances. and i have a carb just sitting around so i thought it would be fun to give it a try. so i thought i would see what you guys say, maybe ill do it. then get back and tell yall how it worked out, i just hope it doesnt flood the engine. thats alot of gas and alot of air.
Josh Egeberg
CCC
PostPosted: Sun Mar 13, 2005 3:08 am
Hi c_creations, all,
......... i just hope it doesnt flood the engine. thats alot of gas and alot of air.
That manifold is only part of the package that makes the 292 run with V8s. The rest of the package consists of mostly custom made parts (read very expensive).
Without the rest of the combo it may run as good as it did from the factory.
Regards,Norm
PostPosted: Mon Mar 14, 2005 3:23 pm
My little '76 Omega has that 250 IL6 witht he integral head/exhaust manifold. It has a 1bbl carb that performs pretty well except I have had a Heck of a time getting it to behave well when cold. I hate the choke on it. Also, it has a throttle solenoid that sticks sometimes and other times will not. If I adjust it correctly everything works fine if it doesn't stick, if it does then the idle is too low. I haven't been able to find a replacement yet. Is it the age of the carb or the design? Rochester 1bbl. Maybe you have had some experience with these Norm? Or anybody...
PostPosted: Mon Mar 14, 2005 11:18 pm
88 coupe, custom parts. like what, would it still work though with out them?
Josh Egeberg
CCC
PostPosted: Tue Mar 15, 2005 1:29 am
Hi c_creations,OldsGuy, all,
......... Maybe you have had some experience with these Norm? .........
More experience with the 235. My only experience with the "late" 6, was the one that came in my '63 Chev II.
Got it for a good price 'cause it had a broken piston.
At 70K it ran perfectly.
When it came time to rebuild it, A 283 V8 took its place.
Nothing wrong with the design, It'll just take some searching for the correct replacement parts.
A good reason to stay friendly with your mom & Pop parts supplier.
You might also try to find a factory shop manual and pay whatever it takes.
......... custom parts. like what?...........
Most everything that moves.
Custom made to the specs you supply, not to be confused with aftermarket bolt ons.
After I posted I got to wondering if Clifford is still in business.
He is still selling aftermarket stuff, so it will be easier and cheaper than I thought.
......... would it still work though with out them?
With luck, and a lot of trial and error, it might run as good as Oldsguy's 250, after he gets it running right.
