Turbocharged400sbc wrote:
Yeah the stock Trofeo front sway bar was a little bigger than an inch in diameter.....and it's now in the back of the 442! corners like she's on rails!
Good luck with the sway bar! J-yards....a gearheads best friend!
James
yeah the trofeos should be in the 32mm range.....that is up front.
He needs a rear sway bar which should be no problem if you can find the brackets on ANY H-BODY car in the junkyard.
