It is currently Thu Nov 12, 2026 6:56 am
 Posted: Thu Apr 28, 2005 9:08 am |
Ok. I know TPS sensor is supposed to be set at roughly 0.4 volts at idle. But, the computer is ok with it being anywhere from 0.25 to 0.6 or so volts.
If I play with this voltage adjustment, would that in turn affect my idle mixture and idle RPM? I havent screwed with it yet, but I think I could make this motor run a tiny bit smoother.... MAYBE?
Also, if you play with idle voltage, you will ultimately be playing with WOT voltage aswell... Can this affect performace slightly? Or does the computer make its own adjustments as you drive?
 Posted: Thu May 12, 2005 10:47 am |
cool... someone HAS been playing with this stuff! Thanks for the info. I'm going to experiment over the next few weeks.
Hans
 Posted: Thu May 12, 2005 10:18 pm |
88delta88 wrote: cool... someone HAS been playing with this stuff! Thanks for the info. I'm going to experiment over the next few weeks.
Do you have the LN3 or LG3 in your car???
 Posted: Fri May 13, 2005 8:40 am |
Not sure, but the VIN code is 3. This is the 3.8L not the 3800.
How would I tell otherwise?
 Posted: Fri May 13, 2005 9:04 pm |
Quote: This is the 3.8L not the 3800
3.8 liters = 3800 cubic centimeters
73Delta88
 Posted: Fri May 13, 2005 11:38 pm |
88 Coupe wrote: Quote: This is the 3.8L not the 3800 3.8 liters = 3800 cubic centimeters
3800 cubic centimeters = 1 Gallon
 Posted: Mon May 16, 2005 9:38 am |
hahaha 73delta... I've got a 1 gallon motor.
