It is currently Mon Nov 09, 2026 8:33 pm
 Posted: Fri Jul 08, 2005 1:58 am |
Hi speedy266, hello All
Quote: .......... facing straight right behind the grille. Can even see it.......... Any obstructions (a headlight) will lessen the ram effect. Quote: .......... Currently i have the 45degree bend facing halfway down because i wasnt sure what would happen in the rain......... If the 45 is at the opening, you'll get less than half the ram, compared to straight ahead. Quote: .......... The pvc pipe is not clamped to the stock plastic piece, its just snugly fits right over it.......... PCV should fit flush with, or inside the stock piece. Quote: .......... I was thinking the most id get would be alot of mist if i was driving behind a semi or pick up truck with no splash guards.......... If you follow at a safe distance you'll have no problem. Quote: Considering my under hood temps are extremely hot the mist would vapourise before it went into the engine.......... Quote: ......... i wanted some advice about the water/mist issue .......... Cool mist can improve economy, but can hurt power. If you are not racing in the rain, no problem. Quote: ......... i wanna get a collecter that collects air and directs into the pipe ......... Megaphone shape is best. The bigger it is, the more ram you get. It should be mounted as low as possible as liquid does not flow up. Air for both my Coupes enter stock fresh air intakes under my headlights with 4" A/C duct going into both sides of their sealed air cleaners. 468 has a 14" X 3" generic paper filter. 439 has a 14" X 4" K & N. 2+ MPH increase in the 1/4 with both setups. No difference at speeds under 50 MPH. Quote: ........... the rpms are lower on freeway driving.
Not possible without a tire size or gear change.
speedy266
 Posted: Fri Jul 08, 2005 10:36 am |
Hey
Right now the only obstruction is my grille, thats where the opening of the piping sits right behind.
The 45 degree bend at the end is to make it sit parrallel with my grill, if i were to face it straight instead of halfway down, would that still affect the whole half ram affect.
Sorry i didnt make it clear, i meant to say the stock plastic piece fits snugly over the pvc piping i added.
Megaphone design, wats that look like? where could i find that design.
Lower rpms are not possible?? I thought that made sense because the engine has to work less now, before it had to work more to pull in the air, now the air is is being pushed in slighty faster.
 Posted: Fri Jul 08, 2005 12:50 pm |
speedy266, unless your locking torque converter isnt locking, the engine and the wheels will be LOCKED just like a manual transmission on the highway. RPM's will be constant at 100km/h.
 Posted: Fri Jul 08, 2005 5:08 pm |
Hi speedy266, All,
Quote: ........... The 45 degree bend at the end is to make it sit parallel with my grill, if i were to face it straight instead of halfway down, would that still affect the whole half ram affect. Quote: Megaphone design, wats that look like? where could i find that design. For best results, the inlet tube must be parallel to the ground as shown here. The narrowing of the tube increases the amount and velocity of the incoming air, which further enhances the supercharging effect. Quote: Lower rpms are not possible?
To expand on 88delta88's statement, the engine might be making more power but it's at the same RPM.
 Posted: Fri Jul 08, 2005 11:33 pm |
Hi speedy266, All
Residential A/C duct, aluminum flex.
Check out the transitions and register boxes at your local Home Depot, Lowes, etc.
Mods can be made with sheet metal shears. Fill the seams with caulking compound.
 Posted: Tue Aug 23, 2005 10:47 am |
cool setup... do you really think he gained 34HP with that mod?
Joes 94 cutty
 Posted: Tue Aug 23, 2005 4:13 pm |
awsome man,...
-Joe
Rockford fosgate AMP 400 watt
Rockford fosgate Sub 400 watt
Pioneer 3 way 355 watt 6x9's
Pioneer Tweeters
Cobra C/B radio 44 watt
P/A speaker for good times
5 foot whip antenna
Brianritchie21787
 Posted: Tue Aug 23, 2005 4:37 pm |
Joined: Sat Feb 07, 2004 11:14 pm Posts: 272 Images: 7 Location: Tolland, CT, USA
speedy266 wrote: making a megaphone/collector design, out of aluminum or plastic? What would be better for intake tubing aluminum or plastic, i was thinking the aluminum would be hotter.
i took a big funnel, cut it in half and aluminum taped the over the whole thing to my aluminum ducting. ran the ducting through the front left fender and it sticks out about 3" under my parking lamps, with only one, gradual 90 degree angle. where it connects to the irregularly shaped hole in my air cleaner i used a vacume cleaner attatchment (yes, a vacume cleaner attatchment) to make it air tight. ill take some pictures next time buy some poloroid
_________________ 1986 Delta 88 Royale Brougham (parted out)
1995 Saturn SL2 (SOLD)
 Posted: Tue Aug 23, 2005 7:14 pm |
Hi All,
88delta88 wrote: cool setup... do you really think he gained 34HP with that mod? I don't think so, Tim. Edit: Reread it and found some useful information. Author seemed sincere, but lacked the knowledge to conduct and describe his tests. No mention of velocity or pressure, only flow. If one leaves out 2/3 of an equation, would one expect an accurate conclusion? karlsnet.com wrote: I acquired several different scoops, and tested them with a High Power Turbo Honeywell fan and a strain gauge I made.
How very scientific. Accurate discription of the apparatus and how the measurements were made should be included. Images are always a big help.
He pressurized his crankcase and lowered the oil temp by 10 or more degrees?
Have I ever mentioned my opinion regarding misinformation on the internet.
 Posted: Sun Nov 06, 2005 7:44 am |
Hmmm...just reading through, as I'm having thoughts of ram air hood for the delta....
Did you call 88delta88, Tim? His name is Aaron....
 Posted: Sun Nov 06, 2005 9:30 am |
Brando wrote: Did you call 88delta88, Tim? .........
Nope, I would have called him 88delta88.
How quickly they forget.
