It is currently Sat Nov 28, 2026 7:19 am
 Page 1 of 1 [ 13 posts ]
 Post subject: Softer gas pedal?
PostPosted: Wed Feb 01, 2006 3:27 pm
The gas pedal in my Intrigue (3.5) is really stiff, takes a lot of pressure to give it gas...and is somewhat hard to keep a constant speed, unless using cruise control. My mom's Intrigue (3.8) on the other hand has a very soft gas pedal....which is definately much easier on the foot and generally less stressful to drive.
I saw this:
http://www.4x4wire.com/tech/josh4x4/techtricks/
I haven't actually looked at the throttle body on the 3.5L, but is that the solution? Or is there something wrong with my throttle? Having an extension would definately make sense....thinking of a breaker bar. :D
Comments, opinions..?
PostPosted: Wed Feb 01, 2006 5:56 pm
I didnt check the link yet, but it could be the throttle cable... if it is that stiff, I would definatly be checking it out!
PostPosted: Wed Feb 01, 2006 6:33 pm
Is the cable worn? kinked? rusted? linkage need to be lubricated? can you use a different spring?
just some thoughts
 Post subject: Re: Softer gas pedal?
PostPosted: Wed Feb 01, 2006 6:59 pm
Hi Brando, hello everyone,
Brando wrote:
Thanks for the link. My '89 has the same problem. I only drive it 5 or 6 times a year, and fixing it isn't high priority.
Is yours a TBI also?
PostPosted: Wed Feb 01, 2006 8:27 pm
The 3.5 would be EFI. :)
Brando, have you tried oiling the linkage area, springs etc.? I know mine was the exact same way, but I oiled it and it worked great.
PostPosted: Wed Feb 01, 2006 8:36 pm
3.4? 3.5L...and no, it isn't throttle body injected.
I'll have to take a closer look...haven't really looked in that area of the engine (throttle body).
PostPosted: Wed Feb 01, 2006 8:46 pm
Yeah, my bad, edited. We were discussing 3.4's on another forum, got confused.
PostPosted: Wed Feb 01, 2006 11:46 pm
Reread it, then think about it. It loses a lot when it has to be explained.
Norm.
PostPosted: Thu Feb 02, 2006 12:46 am
oooo!! ooooo!!! I know! I know!!!
PostPosted: Thu Feb 02, 2006 1:06 am
:laughing:
PostPosted: Thu Feb 02, 2006 7:19 am
Must be missing something...
This repair also applies to any GM throttle body
I have a GM, I do have a throttle body....
:lol:
PostPosted: Thu Feb 02, 2006 10:43 am
brando - put on one of those big-foot gas pedals. It will weigh the pedal down, so its easier to press... ;-)
PostPosted: Thu Feb 02, 2006 12:34 pm
:lol:
Look at the site again... carefully.
btw, after that modification... make sure your aircleaner fits...
Users browsing this forum: Baidu [Spider] and 12 guests
