It is currently Fri Jun 19, 2026 12:38 am
 Post subject: transplant tech support
PostPosted: Fri Jul 14, 2006 2:16 pm
hey all im a newb, and i need lotsa tech support. here's the situation :i have an 84 caprice (probably a bad thing to you guys) with a 305 and th350. i also have a 1979 403 from a delta 88. one goes into the other. here's what i need help with
1- power steering: will it have to be moved?
2- transmission: mine won't fit, correct? will a chevy 200r4 fit? does a olds th350 bolt into my chevy mounts?
3- engine mounts: will my stock ones work ? will they have to be moved?
4-radiator: will i have to get a bigger one? is there a higher performance one of the same size (as in bolt in without modification) ?
thanks for any help, it's very much appreciated
he who makes a beast of himself, gets rid of the pain of being a man
PostPosted: Fri Jul 14, 2006 6:28 pm
Hi sickboy, hello everyone,
power steering: will it have to be moved? ........
Pump stays with the engine, the rest stays with the car.
........ transmission: mine won't fit ........
Use the Olds trans.
........ will a chevy 200r4 fit? ........
No
........does a olds th350 bolt into my chevy mounts? ........
Yes.
........engine mounts: will my stock ones work? ........
engine mounts stay with the engine, Corresponding frame mounts will be in an Olds version of your Caprice.
........radiator: will i have to get a bigger one? ........
From the information you've given, No
PostPosted: Mon Jul 17, 2006 2:26 pm
wicked cool thanks alot
