Everyone:
Please note the difference between “checking/testing” and “replacement”.
yaekle wrote:
........ In the mornings, warm or cold, it starts wonderfully but quite a bit of smoke does come from the tailpipe........
White smoke? What other times do you see white smoke?
yaekle wrote:
........ I'll pull out of the drive ........
Do you head out or back out. If you back out, what happens when you stop, then move forward? What is the time lapse from the start, to this point?
yaekle wrote:
........ then its okay until I come to the stop sign ........
Discribe OK vs the way it is supposed to run.
yaekle wrote:
........ When I accelerate, it will either stall ........ [or] ........ it will pop and hesitate and blow black smoke out of the exhaust ........
Two different results under the same conditions?
yaekle wrote:
........ as long as I do not let off the gas, it will be fine in about three hundred yards or so ........
In this case, does "on the gas" mean acceleration, or cruise?
yaekle wrote:
........ and then fine for the rest of the day ........
Everthing works exactly like it should? No black smoke?
yaekle wrote:
OK. I thought it was the carb because a mechanic I know said that's what it sounds like to him, as he apparently knows the Quadra-Jet .........
Anyone, who knows carbs, would able to tell you which part is causing the problem, and why. If he only knows how to rebuild them, it would explain his diagnosis.
yaekle wrote:
........ I have regularly replaced the spark plugs, and yes they're gapped correctly; air, oil, fuel, PVC valve, hoses, belts all changed .........
........ Vacuum hoses and/or pots? Did you check the distributor advance for proper operation? ........
Base timing should be 20°.
yaekle wrote:
........ No changes except the idler screw ........
That would be the Idle speed adjustmment. That was done 2 yrs ago?
yaekle wrote:
........ it's set where it needs to be so that it will stay running and doesn't constantly blow black smoke
Warm idle should be 600 RPM, in gear.
yaekle wrote:
........ The car has been doing this for about two years ........
And it had no problems before that?
yaekle wrote:
........ Also, it seems to be going through too many exhaust parts- catalytic converters-2 in three years; two mufflers in three years
No help. The cause, is the problem we are working on.
yaekle wrote:
........ I'd just take it to a mechanic ........
Look for a Mom & Pop shop where the owner, or at least one mechanic has, a minimum of, 20 years of tuneup experience. A GM dealer might be a good choice until then.
yaekle wrote:
........ Sorry if I didn't answer all your questions ........
You are trying to tell me everything my own five senses would tell me, if I was there. Do not apologize, just do the best you can.
yaekle wrote:
........ but I'm new to these threads and forums and can't figure out how you quoted text!
In my case, your answers are far more useful than any quotes.
I was thinking that it could be a timing chain ........
There is some evidence of a cam timing problem, but nothing I would bring up, yet. If I thought he was handy enough to check it himself, I would have.
The subject does deserve discussion, but I’m concerned about the integrity of the thread.
........ Since it is spitting and sputtering, the first thing that I would do, is replace the fuel filter.
I would check it, and replace it, if necessary. If he is is paying for the labor, I would not suggest it.
........ I think that one may be in the carb inlet.
Unless another has been added, that would be it.
Regarding the filter vs a new or rebuilt carb: If the filter was the problem, a new one would be in both, and the owner could pay $500.00 for the needed 98¢ part, and never know the difference.
........ In the process, I would do a fuel pump volume check, to make sure your fuel pump is operating ........ I don’t really think its a fuel problem as the symptoms of that are more of lack of power when you hit the throttle.
Good idea, if, he’s not paying someone to do the labor.
yaekle wrote:
........ But when I run Sunoco Ultra 94 regularly, while it still smokes white at start and black on acceleration, it doesn't sputter.........
Useful, it eliminates several possibilities.
yaekle wrote:
........ Also, my stepfather noticed a strong gasoline smell in the motor oil even right after an oil change.........
That's consistent with the black smoke.
yaekle wrote:
........ The PCV was changed less than one year ago, about 10,000 miles ago. I did not change the plug wires as they had been changed about 20,000 miles ago.
Doesn’t mean they are still good. They are on the maintenance schedule and should always be checked at those times.
Should have asked in my first reply. How much of this can you do yourself?
