It is currently Fri Apr 19, 2024 3:04 pm
Posted: Mon May 14, 2007 1:15 am |
TOC Member |
Hi 78supreme,
Quote: ........ havent found anything saying that a ........ Probably because few people would think the gain (if any) will be worth the investment. Quote: ........ ive heard things about adapter plates ........
With your adapter, you can add a bigger carb. Question is: How do you move more fuel/air mixture through the manifold, without enlarging the inlets/ports?
Posted: Tue May 15, 2007 4:48 pm |
TOC Member |
Pounder wrote: I agree, dont waste money and time on a 260 ........ It should be understood, that you are not agreeing with me. I said nothing of the sort. Pounder wrote: ........ If you want more horsepower, drop a 350 into it ........ Because a 350 Chev is best for you, why should it be a good choice for him? Tell us why a 403 would not be better, especially since it is the same engine. Also tell us why he should bastardize his car, as was done in your case. If he were asking about an engine change, we would need a lot more information about his desires/preferences/needs before making any recommendations. Pounder wrote: ........ Parts are plentiful, relatively cheap ........ Yes. Using both definitions, cheap is the operative word. Quote: ........ easy to work on ........ No easier than an Olds. Pounder wrote: ........ It wont be a "numbers" car, so just store the 260 until you want it back in.
Numbers car? Store it?
Pounder
Posted: Wed May 16, 2007 2:03 am |
TOC Member |
Joined: Tue May 01, 2007 10:30 am Posts: 7 Location: Ontario
By the way, yea! store it, take the 260 put it on a engine stand, wrap it up until you are ready to learn how to rebuild it if you dont know already. Please tell me ...uh, NORM....that you know what a "numbers" car means. Come on now, from what Im reading you are trying to come across like some bigshot pro, kind of like above me. But that is just a first meeting assumption.
I also have a 1986 Cutlass Supreme 4 door sedan, 305 high output, 200r4....with 160k on it. Its my winter beater, ...(GASP!) why, cause the frames falling out of it. And when its time to put a bullet in it, Im keeping the drive train, clean it up....and store it.
Pounder
Posted: Wed May 16, 2007 2:25 am |
TOC Member |
Pounder wrote: What is your problem ........ Do I have a problem? Dude! Quote: ........ It was just my opinion ........ And I responded with mine. Got a problem with that? Dude! Quote: ........ And whats with the bastardized car comment ........
Isn't that what it is? Dude!
78supreme
Posted: Wed May 16, 2007 12:13 pm |
TOC Member |
i only read a few of you guys replys... because it seemed like alot of B.S .... is swearing allowed here by the way? dont try to flame the guys post that was just giving an opinion, thats really mean and isnt necessary on a forum about old cars i am actually going to try to find a 350 (OLDS ROCKET!) to rebuild and swap
but speaking of bastardize... thats all you did to pounders posts 88 coupe
88 Coupe wrote: Pounder wrote: I agree, dont waste money and time on a 260 ........ It should be understood, that you are not agreeing with me. I said nothing of the sort.
he is agreeing with what i said about not liking the 260
MantiZ68
Posted: Wed May 16, 2007 4:12 pm |
TOC Member |
Don't even bother brother, 88coupe is like a pair of vice grips handy once in a while but in the end totally useless LOL!!!!!
Check it out http://gbodyforum.com/index.php people who want to inform and have some fun with their cars
Posted: Wed May 16, 2007 8:43 pm |
TOC Member |
Pounder wrote: Yea, I got a problem with that ........ Anything specific? Quote: ........ and you arrogantly tear it apart ........ Arrogantly? What did you read, that I did not write? Quote: ........ I thought this was a forum to exchange ideas ........ Like your first post? Quote: ........ not to criticize others ........ Like your following 3 posts? Quote: ........ Now go ahead, dissect each sentence here and reply ........
Do I need your permission? If so, thank you.
Posted: Wed May 16, 2007 8:58 pm |
TOC Moderator |
If I think I know what you meant, then it must be true...
Just because you think you know what someone might mean, or what 'tone' they have, doesn't mean that you know what they feel.
Reading some of these replies made my head hurt.
Posted: Wed May 16, 2007 9:32 pm |
TOC Member |
78supreme wrote: ........ dont try to flame the guys post that was just giving an opinion ........ That has been, and will continue to be, my practice. Quote: ........ i am actually going to try to find a 350 (OLDS ROCKET!) to rebuild and swap ........ Good choice. Quote: ........ speaking of bastardize ........ The word is commonly used, by Olds enthusiasts, when referring to that combination. Quote: ........ thats all you did to pounders posts ........ Since he has not been able to, maybe you can explain how my opinions and/or my posts can be considered flames. And how his are perfectly acceptable. 78supreme wrote: 88 Coupe wrote: Pounder wrote: I agree, dont waste money and time on a 260 ........ It should be understood, that you are not agreeing with me. I said nothing of the sort. he is agreeing with what i said about not liking the 260
And, as I clearly stated, I was clearing up any possible misunderstanding. If you have a problem with that, explain it. If not, bring on the next example.
Posted: Wed May 16, 2007 10:01 pm |
TOC Member |
MantiZ68 wrote: ........ 88coupe is like ........
OK, we have heard from another who resorts to flames because he is not able to discuss his own statement(s).
Here is an example.
