 Posted: Sat Oct 13, 2007 12:24 am |
91buickman wrote: ........ check out www.crowcams.au
The link does not work. This one does.
I do not see a listing for Buick/Olds/Pontiac.
 Posted: Sat Oct 13, 2007 10:07 pm |
91buickman wrote: Because there are no buick.olds/pontiac in australia ........ OK, there are no BOPs for them to grind cams for. Why did you post the link? 91buickman wrote: ........ there called holden ........
Nothing new. Different name for a different car.
How does that explain why BOP is not listed on that site?
 Posted: Sun Oct 14, 2007 1:33 am |
Why are you reading something that is not there?
91parkave
 Posted: Wed Nov 21, 2007 3:55 am |
Quote: 88 Coupe wrote: OK, there are no BOPs for them to grind cams for.
Norm holden used the same engine diffrent car but same engine, FWD and RWD 3.8 series 1's both share the same internals....
 Posted: Wed Nov 21, 2007 12:19 pm |
91buickman wrote: holden used the same engine ........ You already said that. Here it is again: 88 Coupe wrote: How does that explain why BOP is not listed on that site?
If you are unable to answer the question, just say so.
 Posted: Fri Nov 23, 2007 9:34 am |
91buickman wrote: because BOP's are not sold in Australia ........
Makes sense. They wouldn't grind separate profiles for the Yank version, when Crane and Comp Cams already have cams for our Buicks.
I wonder why you would recommend a lesser product that would probably cost the OP twice as much.
Edited to correct a spelling error.
 Posted: Sat Nov 24, 2007 9:06 pm |
91buickman wrote: Crane or Comp do not offer a cam for series 1 engines ........
According to their websites, they do not. Doesn't mean they will not grind one for an engine builder. Terry at FCR should be able handle it.
There are still hundreds of cam grinders in the US. Cam Motion is another example of one that has a website.
