It is currently Mon Aug 24, 2026 10:26 pm
PostPosted: Sat Nov 03, 2007 12:04 pm
i've been searching everywhere on the web to no avail...
As i was doing some general maint. on my Ciera 3300, i started to wonder how similar it is to the series 1 3800 SC
What im trying to get at is, will the lower intake manifold, and supercharger directly bolt on to the 3300 heads???
also what else would be required to run it outside of swapping the injecters, and the fuel pump, crank pulley, idler, and tentioner.....would the PCM plug right into it or would it not even run??? and would i have a major problem running on a stock tune with the stock 5psi that it puts out???
ive aready replaced the timing chain, waterpump, plugs, wires, ext...
Im not too familiar with OBD1 cars so any help on this would be appretiated
im trying to go for a sleeper and hybrid type of deal, so weather it's worth it or not is irrelivent to me lol
PostPosted: Sun Nov 04, 2007 11:56 pm
gptuner wrote:
........ will the lower intake manifold, and supercharger directly bolt on to the 3300 heads? ........
LG7 manifolds are narrower, due to the decreased deck height of the block.
gptuner wrote:
........ weather it's worth it or not is irrelivent ........
L67 Series II combo, should do the job nicely.
