It is currently Fri Nov 13, 2026 9:15 am
 Page 1 of 1 [ 8 posts ]
 Post subject: Turbo
PostPosted: Wed Jan 21, 2004 8:54 pm
Would it be possible to add a turbo to a 307 engine if so which one.
Josh Egeberg
CCC
PostPosted: Wed Jan 21, 2004 9:50 pm
anything is possible...however, to install a turbo you'd have to do some custom exhaust work, as well as engine work, to get the full benefit of the turbo. Also, if you wanted to install a turbo, I'd seriously consider swapping to a 350, rather than keeping the 307. If you'd swap to a 350, you could do several performance mods, and probably wouldn't even NEED a turbo, let alone the fact that there would be alot of money invested in fabrication costs...
PostPosted: Wed Jan 21, 2004 10:44 pm
Images: 8
I would have to agree with stroke on this. While it would be cool, do you have the money for something like this, it would probably cost close to 5,000 to do everything right.
Jake 19/m
1972 Olds Cutlass- Parts car
 Post subject: Pimpin
PostPosted: Wed Jan 21, 2004 11:58 pm
well 1 ill either have the car my whole life or 2 i can take like a vortech out and put it in something else right so its a win win. at least to me it is.
Josh Egeberg
CCC
PostPosted: Thu Jan 22, 2004 3:38 am
also, gonna need some fuel injection too, running a turbo with a carb is almost impossible.
PostPosted: Thu Jan 22, 2004 9:38 am
Yeah, with a carb, you'd have to do all your regulation via vacuum. That wouldnt be very reliable in my books?
PostPosted: Thu Jan 22, 2004 3:39 pm
Images: 8
You can run a turbo into a carb, you just have to increase your fuel pressure so the fuel doesn't get pumped about into the tank. The early Turbo reagals ran that way.
Jake 19/m
PostPosted: Thu Jan 22, 2004 3:51 pm
correct me if i'm wrong, but early turbo regals were not exactly fireballs when it came to performance.
