DarkFox
 Posted: Wed Feb 20, 2008 4:12 pm |
Joined: Thu Mar 01, 2007 10:49 pm Posts: 77 Images: 3
After the weather warms up a bit more, I'm finally going to lose the catalytic converter.
I'd just like to ask what you think of my way of going about it.
Since the converter has some really odd connection to the rear half of the exhaust pipe, (it goes from the converter into a 3 way pipe, then immediately back into one again!), there is no way I could make a pipe to fit it.
Instead, I will make two cuts where there is only one pipe, and remove the entire thing as one unit, replacing it with a straight pipe.
When the time comes for inspection, I can easily re-install the converter with some coupler piping and heat tape for a few hours.
Questions I have;
My car is very quiet. I have a Flowmaster DeltaFlow on it, and it's STILL almost stock. Is the converter really restricting it (volume wise) that much?
In this is video, the owner comments 'very little piping'. Would it be that loud without a converter, mine does have the flowmaster muffler and a full length pipe.
Link to Oldsmobile Header Pipes
Here's a video of my actual car with the flowmaster.
Link to my video
Edit;
It sounds loud in the video, but it's really not. Notice my voice is louder than the thing.
_________________ 1979 Cutlass Calais - Rolling Restoration & WIP Hurst/Olds tribute (50% complete)
Oldsmobile 350 & TH350
K&N filters
Dual 600 watt amplifier
25" I-INC flatpanel display
Xbox 360 gaming system
 Posted: Sat Feb 23, 2008 3:44 am |
GraveReaper0 wrote: ........ "mexican" muffler shop ........
What does that mean?
 Posted: Mon Feb 25, 2008 8:03 am |
OK, it is not a muffler shop that sells Mexican mufflers.
The explanation sounded more bigoted than the original statement.
DarkFox
 Posted: Mon Feb 25, 2008 12:04 pm |
Is it really true, that there is no smog test for cars 95 and under in New Jersey??
If so, I just as well might run open headers!
Environment be damned!
Not if it's really, ridiculously, 'get-pulled-over-for-noise' loud, though. This must be tested.
I also could pull all the emissions control junk cluttering up my engine too..
WHY, God, WHY is there a pre-heater going into the airbox!!?!
Warm air is bad for power!!!!
K&N filters
 Posted: Mon Feb 25, 2008 6:12 pm |
DarkFox wrote: If so, I just as well might run open headers! Environment be damned! Hearing be damned too...  Quote: Not if it's really, ridiculously, 'get-pulled-over-for-noise' loud, though. This must be tested. I can tell you from personal experience that it is that loud!  Quote: WHY, God, WHY is there a pre-heater going into the airbox!!?! Warm air is bad for power!!!!
You will want that if you are driving around in a New Jersey winter. The heat riser has a valve in the exhaust manifold that moves as it gets warm, and this warms the car up faster, and prevents carb icing. Once the car is warm, hot air is not going into the air cleaner.
DarkFox
 Posted: Wed Aug 13, 2008 9:06 pm |
I'm going to necro this thread, as I don't feel this is worthy of a new topic.
I finally cut the catalytic converter off, and currently I'm running with the exhaust dumping at the down pipe.
I think the converter was clogged, because my car has a LOT more power now. I was never able to chirp the tires from a standstill, but now it can do it with surprising ease, this is definitely not a placebo effect.
Also, the converter weighed about 30~35 lbs!! Why so dang heavy?!
Anyway, here are some videos to compare before and after.
Before (all exhaust piping, catalytic converter, and a flowmaster 40 series)
http://www.youtube.com/watch?v=X_JBX-oVLVE
After (Headers dump at the down-pipe)
http://www.youtube.com/watch?v=2_rPzSfU9Pc
Like you folks said;
It's way too loud to be street legal, but like I suspected not so bad with the muffler on.
I'm in the process of putting up a real replacement pipe, so it will be going through the muffler without wire and heat tape before tomorrow night.
Sounds great, in my opinion.
K&N filters
DarkFox
 Posted: Tue Aug 19, 2008 12:50 am |
I put the muffler right on the header pipe, and dumped it out the side of the car, behind the passenger front tire.
Has alot more power.
The tailpipe was 1" smaller than the header. D:
K&N filters
