 Page 1 of 1 [ 9 posts ]
PostPosted: Tue Jun 03, 2008 3:24 pm
Images: 1
Hey everyone! Hope all is well with everybody. I have a 1985 Delta 88 Royale Brougham 2dr Coupe that has been owned since new. 168K miles. 307 with a 200-4R auto overdrive. Couple of questions: 307 is worn out, has always been a 'slug'. I am replacing it with a rebuilt '79 403 from a Pontiac Trans Am in an effort to keep it 'all Olds'. The engine has been rebuilt; still retains the stock 4A heads. Do not know yet if they have been shaved. I removed the heads for two reasons, to inspect the block/pistons and to have the heads CCs checked to see if they were shaved. The pistons are aftermarket and bear the following numbers...L3067F and separately 30. I have found that these are TRW pistons. I DO NOT KNOW WHAT COMPRESSION THESE PROVIDE but they are dished without valve cuts. I assume the '30' means the block has been bored 30 over. The 403 also contains a newer edlebrock intake, cam and lifters (which I beleive are a matched set of 'RPM Performer'), the cam specs are as follows:
Duration at 0.006" Lift: Intake: 280° Exhaust: 290°
Duration at 0.050" Lift: Intake: 204° Exhaust: 214°
Lift at Cam: Intake: 0.280" Exhaust: 0.295"
Lift at Valve: Intake: 0.448" Exhaust: 0.472"
Timing at 0.050" lift: Open Close
Intake: 4° ATDC 28° ABDC
Exhaust: 49° BBDC 15° BTDC
Centerlines: Lobe Separation - 114° Intake Centerline - 106°
I am looking for the 'perfect' set of headers for this engine. I had some Hedman headers (center dump) ordered from autopartswarehouse but that turned into a fiasco as they took my money and don't have them available. I will obviously install dual exhaust. My main goal is to have a 'sleeper' that is reliable and streetable while trying to be somewhat economical on fuel. Sure could use some help on what the pistons lend for compression, and what headers would be best for the engine and to fit within the confines of this body. I still want to run the A/C, P/S, etc. I am still not sure if I will run the 4A heads shaved or if I will swap for early 70's 350 heads...any suggestions as to upgrades to the current 4A heads would be great as well. THANKS in advance!
PostPosted: Wed Jun 04, 2008 3:03 am
Hi wdcarmichael,
........ Do not know yet if they have been shaved ........
Olds heads seldom need to be resurfaced.
........ L3067F and separately 30 ........
TRW Forged .030" 403 replacement pistons.
........ I DO NOT KNOW WHAT COMPRESSION THESE PROVIDE ........
If you will edit the above, to make it easier for me to read, I will be happy to continue.
PostPosted: Wed Jun 04, 2008 9:09 am
Images: 1
Norm: Thanks for the information. As to your 'edit the above'...I am not sure what you mean but here goes...the compression that I am wondering about is what the TRW dish top pistons add or take away cc's in the chamber over the stock pistons and what the compression may have been changed by had the heads not been shaved (essentially taking the possibility of shaved heads which is unknown out of the equation). Maybe these pistons are direct replacement and the shape of the dish and the .030 calculate back to stock compression. Hope this is more clear.
I know if you shave the heads that you will gain compression, also if these were flat top pistons rather than dish top there would be a gain in compression. Just would like to know if there are specs as to what the L3067F .030 TRW replacement pistons add, subtract or equate to the overall compression mix.
Thanks!
PostPosted: Wed Jun 04, 2008 10:27 am
wdcarmichael wrote:
........ I am not sure what you mean ........
Here it is, again:
If you will edit the above ........
Your use of CAPS, in that manner, is equal to shouting in our faces. Not only is it rude, unnecessary, and insulting, it makes it hard for some people to read.
When you are "logged on" you can see an "edit" button, next to the "quote" button.
PostPosted: Thu Jun 05, 2008 10:37 pm
Images: 1
The use of the all caps was not to be rude or insulting at all...it was to accentuate what information I was trying to attain. Afterall I had a large paragraph with a large bit of information. Didn't know how I might otherwise 'highlight' it in this sea of gray.
PostPosted: Fri Jun 06, 2008 6:15 am
wdcarmichael wrote:
The use of the all caps was not to be rude or insulting ........
Your “intent” has nothing do with anything. If you wish to communicate with adults, post like an adult.
........ Your use of CAPS, in that manner, is equal to shouting in our faces. Not only is it rude, unnecessary, and insulting, it makes it hard for some people to read ........
Which part, of the above statement, do you not understand?
wdcarmichael wrote:
........ it was to accentuate ........
Accentuate = potential confusion.
Questions and answers = accurate communication.
Simply use proper spelling/punctuation, to the best of your ability, and be prepared to answer any questions, you are asked.
wdcarmichael wrote:
........ Didn't know how I might otherwise 'highlight' it in this sea of gray.
Reread this post, then read the following, again:
http://www.oldsconnection.com/forum/vie ... 529f#24239
Does it look, to you, like I need “highlights” to navigate your “sea of gray”?
PostPosted: Fri Jun 06, 2008 8:19 am
In case anyone is interested in my method of "navigation":
wdcarmichael wrote:
Hey everyone! Hope all is well with everybody. I have a ........
Not relevant.
wdcarmichael wrote:
........ 1985 Delta 88 ........
Relevant.
wdcarmichael wrote:
........ Royale Brougham ........
Not relevant.
wdcarmichael wrote:
........ 2dr Coupe ........
By definition, a "Coupe" is a 2 door.
Regardless, not relevant.
wdcarmichael wrote:
........ that has been owned since new. 168K miles. 307 with a 200-4R auto overdrive. Couple of questions: 307 is worn out, has always been a 'slug'. I am replacing it with a ........
Not relevant.
wdcarmichael wrote:
........ rebuilt ........
Relevant.
wdcarmichael wrote:
........ '79 ........
Not relevant.
wdcarmichael wrote:
........ 403 ........
Relevant.
wdcarmichael wrote:
........ from a Pontiac Trans Am in an effort to keep it 'all Olds' ........
Not relevant.
wdcarmichael wrote:
........ The engine has been rebuilt; still retains the stock 4A heads ........
Relevant.
wdcarmichael wrote:
........ Do not know yet if they have been shaved .........
A body shop term, relating to door handles, etc.
"Milled" or "surfaced" is used by any competent machinist I have talked to.
wdcarmichael wrote:
........ I removed the heads for two reasons, to inspect the block/pistons and ........
Not relevant.
wdcarmichael wrote:
........ to have the heads CCs checked ........
Possibly relevant.
wdcarmichael wrote:
........ to see if they were shaved ........
Not relevant
wdcarmichael wrote:
........ The pistons are aftermarket and bear the following numbers... ........
Not relevant.
Relevant.
wdcarmichael wrote:
........ I have found that these are TRW pistons ........
Not relevant.
Needs to be edited, so I can read it.
wdcarmichael wrote:
........ but they are dished without valve cuts. I assume the '30' means the block has been bored 30 over ........
Not relevant.
wdcarmichael wrote:
........ The 403 also contains ........
Not relevant
wdcarmichael wrote:
........ a newer edlebrock intake, cam and lifters ........
Relevant.
wdcarmichael wrote:
........ (which I beleive are a matched set of 'RPM Performer'), ........
Possibly relevant.
wdcarmichael wrote:
........ the cam specs are as follows:
Centerlines: Lobe Separation - 114° Intake Centerline - 106° ........
Possibly relevant.
wdcarmichael wrote:
........ I am looking for the 'perfect' set of headers ........
Possibly relevant.
wdcarmichael wrote:
........ for this engine. I had some Hedman headers (center dump) ordered from autopartswarehouse but that turned into a fiasco as they took my money and don't have them available. I will obviously install dual exhaust ........
Not relevant.
wdcarmichael wrote:
........ My main goal is to have a 'sleeper' that is reliable and streetable while trying to be somewhat economical on fuel ........
Without knowing the destination, a route to it cannot be chosen.
Very relevant.
wdcarmichael wrote:
........ Sure could use some help on what the pistons lend for compression, and what headers would be best for the engine and to fit within the confines of this body ........
Relevant.
wdcarmichael wrote:
........ I still want to run the A/C, P/S, etc. I am still ........
Not relevant.
wdcarmichael wrote:
........ not sure if I will run the 4A heads ........
Relevant.
wdcarmichael wrote:
........ shaved ........
Not relevant
wdcarmichael wrote:
........ or if I will swap for early 70's 350 heads ........
Relevant.
wdcarmichael wrote:
........ ...any suggestions as to upgrades to the current 4A heads would be great as well.
Possibly relevant.
Relevant parts are either questioned, addressed, or clarified. Irrelevant parts are deleted.
PostPosted: Fri Jun 06, 2008 1:59 pm
Images: 1
WOW! You have some issues. What was a possible enjoyable experience in the renovation of my Oldsmobile and sharing information in the internet community on this blog and 'club' has turned into a dramatic Nazi-esque encounter on the etiquette of typing. Your determinatin of relevant and irrelevant is wholly, how can I say this...irelevent! Although I appreciate relevent information I do not appreciate how you deem yourself to be king of the website. Maybe you started this site, maybe you didn't. But your actions of ownership are rude and immature. All due to the use of ALL CAPS! I bid you peace in your remaining time here on earth. But please, consider that we are all mere earthlings and leave the superiority complex you have in your closet.
PostPosted: Fri Jun 06, 2008 3:44 pm
wdcarmichael wrote:
........ You have some issues ........
I respond to what I read. Nothing more, nothing less.
wdcarmichael wrote:
........ Nazi-esque encounter ........
It did not start that way.
wdcarmichael wrote:
........ on the etiquette of typing ........
To one who, it appears, knows nothing about common courtesy.
wdcarmichael wrote:
........ Your determinatin of relevant and irrelevant is ........
Is how I compose my replies. Nothing more, nothing less.
Here it is, again:
In case anyone is interested in my method of "navigation" ........
I find it fascinating that people who cannot read what is actually written, can read everything that is not there.
wdcarmichael wrote:
........ I do not appreciate how you deem yourself to be king of the website ........
And, again, it appears that you read something, into my post, that I did not write.
wdcarmichael wrote:
........ Maybe you started this site, maybe you didn't .........
Nothing to do with anything?
wdcarmichael wrote:
........ But your actions of ownership ........
Responding to what I read. Nothing more, nothing less.
wdcarmichael wrote:
........ are rude and immature .........
Appropriate responses to what I read. Nothing more, nothing less.
wdcarmichael wrote:
........ All due to the use of ALL CAPS! ........
Not as simple as that.
Here it is, again:
Which part, of the above statement, do you not understand? ........
It is a simple statement. It defines your childish attitude.
wdcarmichael wrote:
........and leave the superiority complex you have in your closet.
Nothing to do with any "complex". Everything to do with responding to what I read.
Good luck, in finding someone who is able to answer your questions.
