It is currently Wed Nov 11, 2026 7:23 am
 Post subject: HELP new tach install
PostPosted: Mon Feb 16, 2004 12:28 pm
I have a 69 cutlass conv, that I am trying to find an aftermarket tach that fits in the stock dash, clock pod. I am also running a HEI Pertronix Dist.
1) Does anyone have any suggestions?
2) What anchors the tach in place, since the pod has no real anchoring location?
3) do you have any pictures too?
Thanks
"Some trust in chariots and some in horses, but we trust in the name of the Lord our God."
(Psalm 20:7 NIV)
DigginLou
1969 Cutlass S Conv. W-31c
1984 Hurst / Olds
PostPosted: Mon Feb 16, 2004 6:27 pm
Images: 8
I have mine on my steering colomn in my 72 442, The pervious owner used a big hose clamp to hold it in place, heres a couple pictures, sorry but I don't have better ones
Jake 19/m
1972 Olds Cutlass- Parts car
PostPosted: Tue Feb 17, 2004 7:56 am
Lou, usually the instruments in the dash are secured by a ring around the circumference of the device, near the front, this ring has tabs on it which are parrallel to the face and have holes in them. These holes facillitate mounting with small screws to the back of the dash material. If your other gauges like the speedo are mounted that way and you can see some standoffs of some kind in the place where the clock should be, then perhaps you can find a tach which is the same diameter and use one of those mounting rings, assuming you can find one in a junked car or on ebay. Perhaps getting a stock tach would be the last resort, you could use the mounting ring and resell the tach.
