It is currently Wed Nov 11, 2026 5:07 am
Arelli20
 Posted: Fri Jun 13, 2003 3:02 pm |
Joined: Fri Jun 13, 2003 12:56 pm Posts: 15 Location: Springfield, Illinois
Alright i got this problem right, ive been tring to get that right sound for my 1988 Olds Royale...Now i dont know what size to get, some people say that 3 and a quater inch pipes will give it a growl but i dont want no growl! i dont want a roar, i want an explosion for Christs sake! I heard that if I want to wake tha nighborhood i should get those Double 4 and a half chrome pipes...sooo someone gimme sme ideas....ohhh an does anyone know where i cnget those sparkers that you put in your xhaust pipes so that when you punch tha accelerator it shoots sparks out our pipes??
"C-Dizzzo"
_________________ Yeah, They Call me "C-Dizzzo". Imreppin all my team at D-Boyz Audio Sound and Security..I got 20' Arelli Assassyns on the 1988 Royale..Got 4 15' Rockford Fosgates poundin tha trunk at 1200 watts per sub
 Posted: Fri Jun 13, 2003 6:08 pm |
Not sure bout the exhaust, but if you want some flames coming out of the back, you can get a flame thrower kit from Autoloc. They have a lotta sweet kits to pimp out any car....Lambo Hinge System, Flame Thrower Kits, Suicide Door Hinges, Door Popper Kits, and Split Hood Systems....check em' out!
Primer Death
 Posted: Sat Jun 14, 2003 7:26 am |
Joined: Sun Jun 08, 2003 4:11 pm Posts: 99 Images: 6 Location: Maine
...."ohhh an does anyone know where i cnget those sparkers that you put in your xhaust pipes so that when you punch tha accelerator it shoots sparks out our pipes?? "
that is illegal, but drill a hole in the exhaust, put a heli-coil in(threads for spark plug) get spark plugs, and a couple of cheap coils, mount the coils connect the wires. Be sure to have power to the coils.
Great for carshows, not for highway use.
_________________ The Lead Sled has arrived!
strokercutlass
 Posted: Sun Jun 15, 2003 12:34 am |
| TOC Mechanic |
ok..i GOTTA throw my .02 cents in on this one..Primer Death, Brando...lol..i'm sure ya wouldnt expect any less..  first off...going to an extremely large exhaust system is pointless unless you have the power to take advantage of it, and can actually harm performance more than help it..IF you could run a minimum of 3" exhaust theoretically, it would probably hamper performance more than help, due to the fact of too LITTLE exhaust restriction..this isnt a concern on a carbureted car, BUT..on a fuel injected car, the engine must have backpressure to pick up the proper sensor readings...or else the engine wont feed the correct fuel mixture....now arelli..i know youre question is well intentioned, BUT...you need to decide which you want more of..performance..or the " bling bling" factor...IF, in fact, you could fit 3 1/4" single exhaust, or 2 4 1/2" pipes ( honestly, i dunno WHERE you got that from, bro :? ) the engine wont be able to take advantage of it..kinda like an inverse idea of shoving a orange thru a straw, into a tunnel...too much backpressure at first, and not enough later on...the 3.8 olds engines have always been known to have a "rap", so to speak..its the design of the engine that makes em do this, and is something that you'll usually pick up with em no matter WHAT ya do....2 1/2" is PLENTY on a stock 3.8...shouldnt need any more than that
Spinmaster30
 Posted: Tue Jun 17, 2003 7:26 pm |
| Team Olds Founder |
Joined: Mon Jun 09, 2003 5:46 pm Posts: 4 Location: Michigan
i used 2 & 1/4 exhaust with a exelerater muffler & a cherry bomb for a catalytic converter. people mistake my 3.8 for a V-8
_________________ spinmaster30@aol.com e mail me to join TEAM OLDS. We now have decals for sale $5
73Delta88
 Posted: Tue Jun 17, 2003 7:37 pm |
89Delta88 wrote: ill stick with my straight pipes..  no emission testing for me!
no emission testing for me either  of course that's just because my car is 30 years old! haha
license2ill
 Posted: Sat Apr 17, 2004 11:59 am |
Joined: Fri Apr 09, 2004 9:46 pm Posts: 72 Location: Eureka, CA
Primer Death wrote: A turbo muffler is what you need, It gives a loud roar during acceleration, and growl on the highyway.
That's the exact same kind of muffler I got on my 3.1 Ciera SL. Dual turbo's in the back and yes, they sound very nice! It really does sound like a mild V8. 8)
license2ill
 Posted: Sat Apr 17, 2004 12:14 pm |
Here's the deal - If you really want to make some ear shattering noise, Get an electric cutout available from Quick Time Performance. It's basically like running open headers except that you have the ability to open and close the cut-out valve from inside the car from a button mounted on your dash or center console or wherever you decide to put it at. That's really the loudest you can get... Or you can custom fab pipes coming from the headers going straight out the side of the car like this Grand National shown here...
http://fasttrackperformance.com/page5/C ... isTTGN.wmv
...Now that's f@#%king LOUD!!!:twisted:
BigBlockOlds
 Posted: Sat Apr 17, 2004 10:20 pm |
If you want that kind of sound you need to get an old Olds with a big block.  A 3.8 will never sound "mean".
Arelli20 wrote: i dont want a roar, i want an explosion for Christs sake!
468/T-56/3.73
