It is currently Tue Nov 24, 2026 4:48 pm
Netdewt
 Posted: Mon Apr 05, 2004 8:13 am |
Joined: Sat Apr 03, 2004 8:56 am Posts: 98 Images: 7 Location: Minneapolis, MN
I can almost get car sick in my 1994 Cutlass Ciera because its suspesion SUCKS.
How might I fix this problem, and how difficult is it to fix? I'm no wizard, but I'm mechanically intelligent.
I was thinking about putting in an Eibach kit:
http://eibach.drivewire.com/EibachCatal ... --Kit.html
Quote: Eibach Springs Pro Kit [ 3834.140 ] Eibach Pro-Kit, Front 1.3 in Rear 1.0 in
Fitment Details: Fits: 1993 - 1994 Oldsmobile Ciera FWD, 4 & 6 Cylinder, Excluding Supreme Chassis A-Body
EDIT [better price]:
http://www.autocarparts.com/cars/Oldsmo ... era/Eibach
 Posted: Mon Apr 05, 2004 2:37 pm |
Well...first of all you might wanna check if your struts haven't gone bad...my rear ones are bad (gotta change em' sometime  )
And it's bouncy as hell....changing the springs isn't really gonna help with what you're explaining...
 Posted: Tue Apr 06, 2004 9:14 am |
new set of stiffer struts will cure front to back, and may help with body roll, but you will need to upgrade your springs for sure if you want performance cornering and such...
Maybe a larger sway bar on the front, or if you dont already have one on the rear, see if you can retrofit something... That will help body roll a lot.
 Posted: Wed Apr 07, 2004 8:40 am |
cutlass cierra's the sport models had it I am sure of it... Try and find a junked one with the FE3 package... Maybe the sway bar mounts are even on your car, just not installed as an option!
bdyman
 Posted: Thu Aug 12, 2004 10:11 am |
Joined: Wed May 19, 2004 2:16 pm Posts: 171 Images: 22 Location: chicago baby!!!!
your car is dipping and ride is shitty
ya need new struts lowering springs on worthless struts your askin for trouble
the eibachs will give you great perofrmance, but not that much drop
bigger sway bars, polyurathene bushings,
_________________ how low can you go????........pssssssssttttttttt.....got air???
 Posted: Fri Sep 17, 2004 2:32 pm |
GraveReaper0 wrote: How do I know if I do or do not have a sway bar. On the rear there is a straight square pipe position diagonaly on the axle, is that it? And what about the front?
Look for a bar connecting the two control arms together....it's usually round....
