It is currently Tue Nov 10, 2026 4:06 am
 Posted: Mon Apr 12, 2004 10:02 pm |
Looks pretty clean....what did you use to polish your upper intake?
 Posted: Tue Apr 13, 2004 8:46 am |
How did you handle the intake air temperature sensor? Or does your engine have one?
I know about the deep growl sound the filter gives you, it sounds sweet! Especially straight off the throttle body. The only problem is that you're not really sucking cold air... Have you thought about scooping air from behind the headlights, or is that an option in your engine compartment?
license2ill
 Posted: Tue Apr 13, 2004 3:50 pm |
Joined: Fri Apr 09, 2004 9:46 pm Posts: 72 Location: Eureka, CA
88delta88 wrote: How did you handle the intake air temperature sensor?
For the temp sensor all I did was cut a paperclip in half and plug it into that sensor socket type of thing (can't think of the actual name for that part right now) that the temp sensor clicks into, Kind of like an eliminator I guess. Then I put a rubber vacuum hose over it so it would not get corroded. Seems to work fine and I'm not noticing any differences yet.
license2ill
 Posted: Tue Apr 13, 2004 4:05 pm |
Brando wrote: Looks pretty clean....what did you use to polish your upper intake? TOC Admin Brando
Thanks for the compliment on the job Brando! I used the "usual suspects" for the polishing project... the allmighty Dremel power hand-tool and its corresponding bit numbers in the following order: 8193, 952, and 953 for the removal of most of the coarse surface, then bit 425 for the fine sanding all around after that. Then for the actual polishing stage I used bit number 520 with Turtle Wax brand Rubbing Compound and after that was done, bit numbers 429, 414, and 422 with Turtle Wax brand Polishing Compound. After you finish you can use any good car wax and remove it with bit numbers 429, 414, and 422 if you want to really shine it up. I didn't do the car wax part though because of the time constraints that I had been working under during all of last week.
license2ill
 Posted: Thu Apr 15, 2004 6:23 pm |
88delta88 wrote: The only problem is that you're not really sucking cold air... Have you thought about scooping air from behind the headlights, or is that an option in your engine compartment?
Yeah, I know that it's not a "cold air intake" per say, but that's just kinda the generic term thrown around for it these days I guess.  I really should have called it something like "unrestricted and accelerated velococity air intake" or something to that effect.8) I was thinking about pulling air from the fenderwall, but I did not want any bends in the pipe and the installation for this design was very, very straight forward and simple.
 Posted: Fri Apr 16, 2004 9:02 am |
Sounds good man! Looks good too! I really like the sound a conical filter will give you at wide open throttle, its really mean sounding!
 Posted: Mon Apr 19, 2004 8:39 am |
you can use a resistor instead of the temp sensor IF your climate doesnt fluxuate too drastically... Myself, I just extended the wires long enough to thread the sensor into the front of my conical air filter. (just drill a hole and tread it in, silicone if you want)
I'd be more than happy to use a resistor, but my climate goes from -30 celcius to +35 celcius... To much variance!
