It is currently Wed May 15, 2024 2:27 am
strokercutlass
Posted: Wed Jun 25, 2003 11:11 pm |
TOC Mechanic |
dre,
could you be a bit more specific as to the " i know it has an exhaust, and an intake" quote? stock, modified, or what? technically, unless it has a TON of miles, you COULD run a nitrous setup, if you could set it up in wither a direct port or fogged into the intake configuration..but in order to help ya more, i need more info....
Primer Death
Posted: Thu Jun 26, 2003 10:17 am |
TOC Member |
Joined: Sun Jun 08, 2003 4:11 pm Posts: 99 Images: 6 Location: Maine
strokercutlass wrote: dre, could you be a bit more specific as to the " i know it has an exhaust, and an intake" quote? stock, modified, or what? technically, unless it has a TON of miles, you COULD run a nitrous setup, if you could set it up in wither a direct port or fogged into the intake configuration..but in order to help ya more, i need more info.... He's right... I usually agree with him
_________________ The Lead Sled has arrived!
88Ciera_SC
Posted: Thu Jun 26, 2003 4:07 pm |
TOC Member |
DRE17 wrote: I Have had my 94 cutlass ciera for a while know it has a exhaust and a intake. I made a little power and I don't nearly have a enough for a RSM supercharger or nitrous does any body have any Ideas how to make more power. I almost got beat by a civic with a girl driving lol.
i find your comment alil sexist....lol
are you telling me that getting beat by a woman is a bad thing...
or is it the civic that is the problem
also think that racing on public streets is stupid and childish...
oh wait your 18....YOUR FORGIVEN...my bad
73Delta88
Posted: Thu Jun 26, 2003 4:59 pm |
TOC Moderator |
geting beat by a woman is bad...
geting beat by a civic is bad...
but geting beat by a woman in a civic??
Primer Death
Posted: Thu Jun 26, 2003 5:31 pm |
TOC Member |
88delta88 wrote: Go buy yourself a couple of those "octane boosters" at your local gas station and put them in with your gas... It'll maybe make a couple extra horses for that tank of gas anyways...
Also, get rid of anything in the car you dont need (passengers, subwoofer boxes, tool kits) I find that weight has quite a substatial impact on pick-up. Also, i dont know if anyone would agree with me, but I like to have 1/2 tank or less of gas when I need pickup, just because gas = weight. Just be careful, the octane boost could damage your engine...
strokercutlass
Posted: Thu Jun 26, 2003 7:07 pm |
TOC Mechanic |
ahhh octane boosters....yet ANOTHER thing to fill everyone in on....octane boosters tend to lead a person to believe that if youre running 93 octane..and add a bottle of 110 octane boost..that it will raise your octane rating 5-7 points...which is TRUE...however..its not 5-7 FULL points, but 5-7 TENTHS....so in reality..youre not going from 93-98 octane..youre going from 93 to 93.5 octane rating....granted, this will increase somewhat with more than one bottle, but ya get the general idea
..oh..and primer death... kissin ass IS a good thing LMAO
strokercutlass
Posted: Fri Jun 27, 2003 9:27 pm |
TOC Mechanic |
you wont want to run 110 in your car..it will mess with and possibly burn out the oxygen sensor.....if you can get it for $3 a gallon, youre doing great...its $175 for a 50 gal. drum thru work..plus a $30 drum deposit..otherwise..going price is about $4 a gallon here....and i know this ALL too well, as thats all that i can run in the cutlass...which has come down to more like " gallons to the mile"...lol
Posted: Fri Dec 26, 2003 11:25 pm |
TOC Admin |
speedyguy wrote: Your exhaust should not be messed with too much or a naturally aspirated engine can loose power quickly.
So for the intake make sure the intake pipe is not larger than a 3" OD.
You do not need a filter bigger than a 5-6" K&N filter.
Exhaust should be kept at the same diameter or only slightly larger. Increase flow at the muffler and add a high flow cat.
For the biggest gain after the exhaust and the intake pipe add a set of ceramic coated exhaust manifolds.
Then add a throttle body spacer made from phenolic.
How much does all this cost?
