Hi 88delta88, all,
Funny, but no one has brought up in the past the effect of altitude on an engine's performance .........
No reason to. It only affects one TOC member that I know of, and he has it under control. Under normal circumstances, if two cars are racing each other, they will be at the same altitude.
........ WHERE you race your car can make a big impact on how it performs ........ At sea level air is much denser than up in the rocky mountains ........
More dense means more oxygen in a given amount of air. Not only altitude, but temp, barometric pressure, and relative humidity determine the density of the air. Vary any of these and you change the oxygen content in the air. Less oxygen=less power.
........ How come we never hear about this phenomenon? ........
Because you never asked?
The information isn't needed unless one needs to run a specific number, or is able to rejet to compensate for any changes.
Pros use portable weather stations to make needed adjustments between passes.
........ How pronounced is this effect?
At sea level, my Grey Coupe ran 11.9xx. At 3000 ft, it ran 12.5xx in early morning and evening. Mid day is a different story. At that same strip, I've seen weather conditions equal to 5500 ft and higher. Made the same setup run 13.xxx.
Difference is less with a blown or squeezed car.
FWIW: Exhaust driven superchargers were developed during WW II to enable piston engines to run at 30,000 ft altitudes.
