It is currently Sat Nov 07, 2026 6:26 pm
 Page 1 of 1 [ 6 posts ]
 Post subject: Help With Plug Wires
PostPosted: Mon Sep 20, 2004 2:18 pm
Hey Guys sorry its been a while but i got a question about spark plug wires, this summer i bought a 1992 Camaro Rs 3.1L V6 (thats gonna be a 350 soon) anyway my plug wire boots and wires burn up to quickly i got duals on the car but the car runs about 215 and stays but my plug wires cant handle it so i need to know what to get ASAP i wanna get them today! :?
PostPosted: Mon Sep 20, 2004 8:51 pm
http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
PostPosted: Tue Sep 21, 2004 11:56 am
http://performancecenter.com/products/? ... ID=1160051
PostPosted: Tue Sep 21, 2004 11:57 am
A little cheaper and rated at 550 degrees:
http://performancecenter.com/products/?productID=5986
PostPosted: Sun Sep 26, 2004 11:16 pm
Are your plug wires getting too close to the exhaust? These cars in V8 form generally run in the 210-220 degree range right off the showroom floor with no ill effects to the plug wires...V6 cars in the same range or slightly less temp...the fan switch is designed to turn on at about 210-215 degrees, so it's not uncommon to see these cars run in this range. By the sounds of it the wires themselves are too close to the exhaust manifolds...if this is the case any plug wire will burn up on you...you may need to go to a different type/angle of spark plug boot to cure this problem..
PostPosted: Mon Sep 27, 2004 11:43 am
Hi The J MAN, hello all
I'm with Stroker.
If nothing under the hood was changed from stock, the wrong wire set was used and the cheapest OEM replacement will work just fine.
If something was changed, change it back or you'll toast even the most expensive wire set.
BTW did I ever mention the high dollar wires negative performance gain vs OEM? :lol:
