It is currently Fri Nov 06, 2026 9:17 pm
 Posted: Thu Sep 23, 2004 9:49 am |
GraveReaper0 wrote: get smaller springs. air bags if u got the money..
If you get smaller springs, you should also upgrade the struts.
 Posted: Thu Sep 23, 2004 6:10 pm |
Sway bars aren't struts....
Also, Eibach has springs for the 1993-1994 Cutlass Ciera....but not 1989...
 Posted: Thu Sep 23, 2004 7:21 pm |
They usually come with them stock, I know mine has front and rear.
But here is an upgrade for the rear anti-sway bar on our 88s:
http://performancecenter.com/products/? ... torder=ADA
 Posted: Sun Oct 17, 2004 4:39 am |
Hi Brando, All
The difference between 3.2 and 3 turns is not much. Are you sure of those numbers?
That difference wouldn't be worth my time unless I was replacing a worn out box anyway.
 Posted: Sun Oct 17, 2004 9:10 pm |
Well yea, you have the Sport Suspension...which is just another name for the FE3. Only 2 turns lock to lock, eh? Cool...I have something a little more to look forward too after buying the sport rack & pinion.
