It is currently Fri Nov 06, 2026 9:37 pm
 Page 1 of 1 [ 8 posts ]
PostPosted: Wed Sep 29, 2004 9:22 pm
Does anyone know what bhp stands for? Every site I check for my car says 148 bhp. Is it the same as hp or diffrent?
**Official Xbox Live beta tester**
**Official Member of LP UNDERGROUND**
Currently playing Halo 3, Mass Effect, Call of Duty 4
PostPosted: Wed Sep 29, 2004 9:30 pm
It's basically the horsepower at the crank.
Here's the full definition:
The measure of an engine's horsepower without the loss in power caused by the gearbox, alternator, differential, water pump and other auxiliaries. The actual horsepower delivered to the driving wheels is less.
PostPosted: Wed Sep 29, 2004 10:43 pm
BHP = Base Horse Power
PostPosted: Thu Sep 30, 2004 9:15 am
Actually it's Brake Horsepower, or Crank Horsepower :wink:
PostPosted: Thu Sep 30, 2004 11:54 am
who coined the term "horsepower"? I have this feeling that we are degrading the status that horses used to hold "back in the day"... A full-grown horse could exert much more than one measly horsepower.
The power of a horse is also dependant upon the physical status, nutrients, and motivation of the animal. Much like an engine in many ways I suppose...
Excuse my ramble, I havent done so in a while... :-)
PostPosted: Thu Sep 30, 2004 2:37 pm
The term was invented by James Watt in the 1700’s.
He wanted to be able to talk about the power developed by horses used in coal mines.
He determined that the average horse could complete 33,000 ft-lbs.. Of work in one minute. :D
PostPosted: Thu Sep 30, 2004 4:32 pm
:oops: #-o
PostPosted: Thu Sep 30, 2004 5:43 pm
Hi All
Brando is correct re. James Watt and the HP standard.
HP and BHP are the same.
BHP stands for brake horsepower, and it is measured at the flywheel.
The term comes from the type of machine used to measure horsepower.
A dynomometer applies a braking force against the flywheel while the engine is under full acceleration and measures the amount of "brake" needed to contain the torque of the engine at given RPM.
The torque figures are then used in a math formula to calcuate the HP figures.
Prior to 1972, the manufactures ran these tests with only a water pump (it was needed for cooling). At that time the US government required that all future testing be done with all accessories attached.
BTW a chassis dyno works exactly the same, except the power is measured at the rear tires instead of at the flywheel.
