 Page 2 of 2 [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Mon Oct 16, 2006 11:21 am
adma449 wrote:
Power dosent come cheap, and bolt on's are definetly not the answer. Upgrade to a rocket (350), or dish out the cash to bore it out.
Is ok to bore out a 307 to 350. that would save me a lot of head ache if so
PostPosted: Mon Oct 16, 2006 12:02 pm
Biggest pistons available for a 307 is .060 over.
Stock bore and stroke is 3.800" and 3.385" respectively.
[(1.9")^2*PI*3.385]*8 = 307.118 that's the current cubic inches...volume.
[(1.93")^2*PI*3.385]*8 = 316.893 that's the volume in cubic inches with the .060" oversize pistons.
How do you plan on boring it out to 350?
Even with the oversize pistons, the stroke would need to be 3.73865--.353645 over stock....and as far as I know there isn't even a stroker kit for the 307. 350 and 307 are totally different engines.
PostPosted: Mon Oct 16, 2006 12:13 pm
i was just wondering if it would be possible. i have a shop i go to for various things i need done when working on cars.
PostPosted: Mon Oct 16, 2006 6:16 pm
You'd have much less headaches dropping in an Olds 350 if that is what you're after.
PostPosted: Mon Oct 16, 2006 6:33 pm
will the olds 350 will bolt in a 84 delta 88 with no mods? if there are mods that need to be done, what are they?
PostPosted: Tue Oct 17, 2006 6:31 am
Hi Jeht Black, hello everyone,
adma449 wrote:
........ bolt on's are definetly not the answer. Upgrade to a rocket (350), or dish out the cash to bore it out.
He did hot say "bore it out to 350". The statement is misleading, at best. Any overbore, by itself, is less cost effective than the bolt ons he rejected
FWIW: All Olds V8s from '49 to '90, are Rockets.
Jeht Black wrote:
will the olds 350 bolt in an 84 delta 88 ........
Yes. Externally, all SBO (small block Olds) are the same and are interchangeable. Use your existing bracketry and you'll be fine.
Brando wrote:
Biggest pistons available for a 307 is .060 over ........
Yes, if you only shop on the internet.
Brando wrote:
How do you plan on boring it out to 350? ........
Actually he would bore it to 4,057". Any top quality shop could do it for him. Not cheap, and they would also advise him to use a 350 block. But if he wanted to pay ........
Brando wrote:
........ as far as I know there isn't even a stroker kit for the 307 ........
Right. Or for any other Olds. Kits are for those who want to follow the crowds. Individuals make their own kits.
Anyone want to guess how my 425 grew to 437?
Brando wrote:
........ 350 and 307 are totally different engines.
There are lttle, if any external differences between the SBOs (307, 330, 350, and 403). Internally, the block castings were changed to accomodate the different cylinder bore diameters. Crankshafts are all dimensionally the same.
307 heads were cast with smaller ports to match smaller CID, but also in order to meet the stricter emissions standards of the late '80s. Externally, except for going from 10 to 5 bolts per valve cover, and the smaller ports, they are the same.
PostPosted: Tue Oct 17, 2006 5:40 pm
So it is possible to bore the 307 out, and put 350 pistons in it? I was thinking of it as I was posting that reply, thanks for the heads up. Perhaps I should have read this before posting... :lol:
Not sure by what you mean: "Yes, if you only shop on the internet." .060 is what Clevite states is the biggest oversize piston available for that year 307, as well as any local auto parts store would say...unless the parts person happened to be experienced with Oldsmobile V8 engines, specifically the 307.
As to how you got the 437, taking a guess...
.060 over pistons would make it a 437, I see no listing for a 425 at federal-mogul's website. So I'm guessing you used the .060 over pistons for a 455 since it has the same stock bore size as the 425.
If he was to have the 307 bored out to a 350...would they add sleeves for added strength and reliability? I've never had an engine bored, how much does it usually run? I'll find out soon enough, but just wondering.
PostPosted: Wed Oct 18, 2006 2:03 am
Brando wrote:
So it is possible to bore the 307 out, and put 350 pistons in it? ........
Yes, possible, just not practical.
........ Perhaps I should have read this before posting ........
Anything good in it?
........ Not sure by what you mean: "Yes, if you only shop on the internet." ........
I don't think I'd be looking on the internet for a 3¾" piston for a 307 Olds. Odds would be better at my local machine shop.
........ .060 is what Clevite states is the biggest oversize piston available for that year 307 ........
For only that year? How about another manufacturer?
........ unless the parts person happened to be experienced with Oldsmobile V8 engines, specifically the 307 ........
Or just good at reading parts catalogues?
........ .060 over pistons would make it a 437 ........
Close. Did you think I'd bring it up if it was that easy?
437.97921237728985 = 438
437.14609569598510 = 437
........ I see no listing for a 425 at federal-mogul's website ........
I did not use Federal mogul pistons.
........ So I'm guessing you used the .060 over pistons for a 455 since it has the same stock bore size as the 425 ........
Good, you are beginning to think outside of the box.
425 and 455 have different strokes and rod lengths. The pistons have the same 4⅛" diameter, but the 425 compression height is 1.612" and the 455 is 1.735".
Using the same 7" rod, the 455 CH would have to be about ⅛" shorter. Removing that much from a piston top, would probably render it useless. I used the 7" rods.
........ If he was to have the 307 bored out to a 350...would they add sleeves for added strength and reliability? ........
No. They would add the sleeves to keep the coolant in the water jackets.
........ I've never had an engine bored, how much does it usually run? ........
Depends on many factors. The geographical area, the shops hourly rate, and how much material is to be removed, are a few.
You have not talked a shop yet?
PostPosted: Sat Oct 21, 2006 12:38 am
Give up?
4.185 x 3.980 = 437.97921237728985 = 438
4.155 x 4.030 = 437.14609569598510 = 437
Thirty over Badgers were in it (.039" in the hole) already. Due to a spun bearing, the crank needed repair, so it got offset ground.
.050" extra stroke got the pistons up to .014", and the CR from 8.8 to 9.6.
Users browsing this forum: Baidu [Spider] and 15 guests
