It is currently Wed Nov 18, 2026 9:23 am
Hans
 Posted: Thu Feb 17, 2005 12:23 am |
Bad fuel pressure regulator or pump most likely. Probably not the filter since you claim the car was running good prior.
It could be an ignition issue like bad coils or bad plugs/wires but usually that will cause the engine to run real bad.
88Ciera_SC
 Posted: Thu Feb 17, 2005 1:56 am |
stupid answer but it is either a spark or fuel problem..
thats about all i know for sure..
well maybe not for sure..lol
check for a spark
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
Oldsmowbill
 Posted: Thu Feb 17, 2005 6:11 am |
Joined: Fri Dec 10, 2004 6:08 am Posts: 22 Location: Campbellsville, Ky
Quote: Could be the fuel pump relay...but you say you actually heard the pump running in the tank?
I can't hear that good at all but my friends say that they heard it.
I'll check for spark first and then, I think I'll take the fuel line off on the engine side of the fuel filter and crank on it to make 100% sure that it is pumping fuel.
Any thing else it could be if I am getting spark and getting fuel?
 Posted: Thu Feb 17, 2005 11:53 am |
Oldsmowbill wrote: Quote: Could be the fuel pump relay...but you say you actually heard the pump running in the tank? I think I'll take the fuel line off on the engine side of the fuel filter and crank on it to make 100% sure that it is pumping fuel.
Make sure you pull the fuel pump fuse out and crank the car for a while to alleviate any pressure that may possibly still be in the system.
Hans
 Posted: Thu Feb 17, 2005 2:23 pm |
Oldsmowbill wrote: Quote: Could be the fuel pump relay...but you say you actually heard the pump running in the tank? I can't hear that good at all but my friends say that they heard it. I'll check for spark first and then, I think I'll take the fuel line off on the engine side of the fuel filter and crank on it to make 100% sure that it is pumping fuel. Any thing else it could be if I am getting spark and getting fuel?
dont do that. replace the fpr first it is cheap. just because there is a noise does not mean it is working always.
is this a 3.1?
 Posted: Thu Feb 17, 2005 3:25 pm |
Hans wrote: Oldsmowbill wrote: Quote: Could be the fuel pump relay...but you say you actually heard the pump running in the tank? I can't hear that good at all but my friends say that they heard it. I'll check for spark first and then, I think I'll take the fuel line off on the engine side of the fuel filter and crank on it to make 100% sure that it is pumping fuel. Any thing else it could be if I am getting spark and getting fuel? dont do that. replace the fpr first it is cheap. just because there is a noise does not mean it is working always. is this a 3.1?
I believe I remember from his first topic that he has a 3300, the 3.1 wasn't available on the Cutlass Ciera in 91.
 Posted: Thu Feb 17, 2005 9:48 pm |
Hi Oldsmowbill, hello all,
Quote: ............. I'll take the fuel line off .............. and crank on it to make 100% sure that it is pumping fuel .............
Fuel injection pump must be checked with a pressure gauge.
From your description, the problem is lack of spark.
Oldsmowbill
 Posted: Fri Feb 18, 2005 12:38 am |
Quote: dont do that. replace the fpr first it is cheap. just because there is a noise does not mean it is working always.
is this a 3.1? It is a 3.3. What is, and where is the Fuel Pump Relay? Quote: Fuel injection pump must be checked with a pressure gauge.
So, there is no good way to check it without a gauge?
 Posted: Fri Feb 18, 2005 1:19 am |
The Fuel Pump Relay is located in the RH (Driver's side) front of engine compartment, on relay bracket.
Diagram
THIS is a relay.
 Posted: Fri Feb 18, 2005 2:32 am |
HiOldsmowbill, all,
Quote: ................ So, there is no good way to check it without a gauge?
Pumps for carbs can be checked by measuring flow, but injector pumps flow the same, but at much higher pressures.
I don't know exact numbers, but if your injection system needs 40# or more, and your pump only puts out 20#, how would you know without a gauge?
Did you check the spark yet?
