It is currently Tue Nov 10, 2026 3:06 am
 Page 1 of 1 [ 10 posts ]
PostPosted: Tue Aug 23, 2005 9:53 pm
Where is the cooling fan relay on an '89 Ciera ? The car has 3.3 V6.
PostPosted: Tue Aug 23, 2005 10:16 pm
RH front of the engine compartment (firewall), on a bracket...usually covered by a piece of plastic.
PostPosted: Wed Aug 24, 2005 4:22 pm
Hmm... I did not find the fan relay on the passenger side firewall, I
looked near the heater fan and A/C.
There is a row of four identical looking modules on that side of
the car near the radiator, behind the headlights. All look the
same to me.
PostPosted: Wed Aug 24, 2005 7:00 pm
Ok...yea..I misread the diagram :blush:
Yes, they are located behind the headlight, passenger side.
From driver's side to passenger side, they are:
Fuel pump, A/C Compressor Control, Blower, and then the Coolant Fan relay.
PostPosted: Tue Aug 30, 2005 12:33 am
I replaced the relay, but the fan still does not operate. Using jumpers I verified that the fan motor works. The car overheats in traffic.
PostPosted: Tue Aug 30, 2005 1:43 pm
Hi TimKeith, hello everyone,
........ Using jumpers I verified that the fan motor works. The car overheats in traffic.
Would have been a much better thread starter, but you know that, now.
Assuming the new relay is not DOA, you need to find out if the temp sensor actuates it when it is supposed to.
Temp sensor and relay can be tested the same way you tested the fan.
PostPosted: Thu Sep 01, 2005 6:40 pm
Where is the temperature sending unit on the 3.3 V6 ?
PostPosted: Mon Sep 05, 2005 10:15 pm
The cooling fan is working again!
PostPosted: Mon Sep 05, 2005 11:21 pm
ok, what did you do to fix it?
PostPosted: Thu Sep 29, 2005 9:35 am
Images: 1
temp sending unit should be on the intake between the alt and power steering pump..i may be be wrong but look there.
