It is currently Sun Nov 08, 2026 5:06 pm
 Page 1 of 5 [ 63 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: little more speed
PostPosted: Wed Jan 18, 2006 2:14 pm
I want more launch from my 77 Cutlass. She does fine once she is off the line. But a little quicker would help me. don't want to go broke either.
PostPosted: Wed Jan 18, 2006 3:10 pm
If you want better launch then buy some stickier tires. Also practice makes perfect.
PostPosted: Wed Jan 18, 2006 6:46 pm
I think it would be proper to ask what you have done so far? Is it completely stock or have you done any modifications to it? Then we can go from there.
 Post subject: Re: little more speed
PostPosted: Wed Jan 18, 2006 7:46 pm
Hi bigdog, hello everyone,
........ I have a 77 Cutlass ........
Tell us about it.
Is the carb 2 or 4 barrels?
Is the engine/powertrain original and/or is it up to handling more power?
........ would love more horses from bolt ons ........
How much are you looking for? Not much bang for the buck from just bolt ons.
What's your budget?
What's your skill/experience level?
What will you use the car for, and what are your long term plans for it?
Since every modification is a trade off, how much comfort/driveability are you willing to give up for more power?
Your answers to the above questions will help provide the path to the most gain for the least cash.
Best start, is a standard tune up, along with a compression test.
........ need more launch because it takes awhile to get the weight moving ........
Best way is to change to lower rear end gears. What ratio depends on your answers to the above questions.
 Post subject: more speed
PostPosted: Thu Jan 19, 2006 8:48 am
My 77 Cutlass is stock. Just really acquired it. 4 barrel carb with the 350 olds rocket engine. Did put flowmasters on it and she sounds beautiful. Like I said once she is gone she is gone. Just getting out of the hole seems sluggish because of the weight of car I guess. She gets way pass anything on the dash with no problem. I usually go about 25-30 mph and nail it if I'm messing with somebody and usually do real well. I drive it everyday and she is very comfortable. People are always askig to buy it. But I look at them like they are crazy.
 Post subject: Re: more speed
PostPosted: Thu Jan 19, 2006 12:19 pm
Images: 5
weight reduction is like free horsepower
3 time G-body owner
 Post subject: getn the 77 moving
PostPosted: Thu Jan 19, 2006 1:07 pm
still waiting on you guys to help me get this 77 Cutlass out of the starting block quicker
 Post subject: Re: getn the 77 moving
PostPosted: Thu Jan 19, 2006 1:12 pm
What's your budget?
Answering said questions would be a good start...
PostPosted: Thu Jan 19, 2006 1:21 pm
btw, when you want a thread to return to the top, you reply to your FIRST post with "TTT" if it has fallen down the list of threads. Threads are listed in order of last reply, so if your thread is still at or near the top there is no need to start a new thread or post "ttt" in a thread.
So in closing...
We will help as soon as we get there.
btw, welcome to TOC!
PostPosted: Fri Jan 20, 2006 10:15 am
andrewwk, i love the chill pill. I am going to have to steal that image. 250,000mg... hahaha!!!
PostPosted: Sat Jan 21, 2006 3:30 am
Hi All,
Looks like Deja Vous all over again.
Haven't yet been able to understand how some people can expect everyone on the internet to jump at his/her command.
bigdog wrote:
still waiting on you guys ........
Being rude will not get quicker responses, especially when you haven't read those you've already received.
PostPosted: Sat Jan 21, 2006 3:41 pm
If I may, first thing to do is reduce weight. Not always so easy. Sticker tires help a lot!.
If you can spare a few hundred bucks, get a cam and a stall convertor. Headers would help too. These 3 things will add quite a few ponies, on a budget, without getting in too deep.
There are also HP kits for the quadrajet. And I'm not sure if yours has a vaccum secondary. If it does, you need to change it to progressive linkage. K&N air filter, slightly hotter plugs, Cold Air Intake, shift kits, (B&M makes a good one for the 350 TH), lock-up rear end, maybe a lower gear ratio.
There are tons of bolt ons that help, without getting into the engine too deep. Some of these are not that cheap, depending on what cheap is for you, some are more expensive. If you are a do-it-yourselfer, it helps.
There are so many ways to get a V8 fast. Depends on what you spend.
1995 Regency Elite 98
6 bodies in trunk.
PostPosted: Sat Jan 21, 2006 6:05 pm
Hi All,
87Delta wrote:
If you want better launch then buy some stickier tires ........
Waste of money unless he has a traction problem. He doesn't.
brando wrote:
........ Is it completely stock or have you done any modifications to it? Then we can go from there.
Good Call.
........ Best way is to change to lower rear end gears. What ratio depends on your answers to the above questions.
Another good call. 8)
Pretty much everyone knows it to be a fact. Not many know how. Please tell us how he should go about it.
And yet another good call.
........ reply to your FIRST post with "TTT" if it has fallen down the list of threads ........
Or you could post "Bump" as we did when "TTT" still meant "Thought That Too" as in "I agree".
RednBlackCutlass wrote:
........ get a cam and a stall convertor. Headers would help too........
Cam and Headers will show improvement in the higher RPM, where he is happy with what he has. Stall converter will show little improvement with his current high gears.
........ These 3 things will add quite a few ponies, on a budget, without getting in too deep.........
On whose budget? We don't know what his is, yet.
........ There are also HP kits for the quadrajet........
Please post the link.
........ And I'm not sure if yours has a vaccum secondary. If it does, you need to change it to progressive linkage........
Please explain.
........ K&N air filter, slightly hotter plugs, Cold Air Intake, shift kits ........
Assuming any of these would provide at least some gain, how would any of them improve his 0 to 30 MPH acceleration.
........ B&M makes a good one for the 350 TH ........
:laughing: Excuse me, but, a basic home made shift kit is far better than the B&M.
PostPosted: Mon Jan 23, 2006 2:05 am
Images: 5
weight reduction on a 77 shouldn't be hard at all, if the primary concern is the 1/4 mile start getting tid of creature comforts like A/C, the radio, the backseat, carpet, any emissions crap (check local laws first). look into fiberglass replacement parts, lighter front suspension, relocation of weight (i.e. battery to the trunk), this can go on forever. really depends on what his goals and budget are....if the 1/4 is his primary goal, I'd drive the 77 and find something smaller to race
3 time G-body owner
PostPosted: Mon Jan 23, 2006 3:22 am
DrRansom442 wrote:
........ A/C, the radio, the backseat, carpet, any emissions crap ........ fiberglass replacement parts, lighter front suspension, relocation of weight (i.e. battery to the trunk) ........
My mistake, I didn't notice he was asking how to build a race car.
