It is currently Tue Nov 10, 2026 6:21 pm
 Page 1 of 1 [ 13 posts ]
 Post subject: Acetone
PostPosted: Fri May 19, 2006 3:36 pm
Everyone, check this link out. VERY intriguing.
Acetone Fuel Additive
Could it actually work, to the extent they describe? I've heard this from a few different sources, and now a scientific description of why it works. I think I'm going to try it this weekend... :-)
PostPosted: Fri May 19, 2006 4:01 pm
Actually doesn't work. I've heard of people doing this and actually got worse gas mileage. Plus, they tested it on Mythbusters as well and they saw like a 2mpg decrease.
IMO, it wouldn't be worth the trouble.
PostPosted: Fri May 19, 2006 8:08 pm
Heres a topic that was recently hashed out over on ROP...
http://www.realoldspower.com/phpBB2/vie ... ht=acetone
Hope that clears things up!
 Post subject: Re: Acetone
PostPosted: Fri May 19, 2006 9:12 pm
Hi 88delta88, andrewk, hello everyone,
I prefer to take it apart at it's source, whenever possible.
........ I've heard this from a few different sources, and now a scientific description of why it works........
How scientific can it be if it won't stand up to a couple of simple questions.
http://pesn.com wrote:
........ Surface tension presents an obstacle to vaporization. For instance the energy barrier from surface tension can sometimes force water to reach 300 degrees Fahrenheit before it vaporizes. Similarly with gasoline ........
How much below that 300° does gasoline vaporize? What is the temp in a typical combustion chamber?
There is a wealth of misinformation on the internet. Tenth post down on this thread is a good example.
........ That's a North American Rockwell, promotional film from the mid seventies.
It was done after North American Aviation merged with Rockwell-Standard (owner of Aero Commander) in 1967 to become North American Rockwell, and before Rockwell sold it's General Aviation division to Gulfstream in 1980, its Sabreliner division to Sabreliner Corp in 1983 and the rest of it's aerospace interests to Boeing in 1996.
The product was well ahead of it's time, and I've often wondered how Boeing put it to use, and how the design has evolved.
PostPosted: Sat May 20, 2006 10:50 pm
:-) good post.
PostPosted: Sat Jan 06, 2007 7:42 pm
Just saw the mythbusters episode. :lol:
They tested it on a cutlass supreme for carbureted engine and some older fuel injected toyota econobox thing. Both lost MPG as said, they also tested those magnets that snap on the fuel line....no change. :lol:
PostPosted: Sun Jan 07, 2007 12:31 am
I saw that too, they also had some "super carburetor" they purchased. Worked like a regular carb, and had even lower efficiency than what came in the car.
Hard to imagine that whoever was selling those is still in business, although I guess there are alot of suckers in the world.
As said in the show, the thermal efficiency of an internal combustion engine just won't allow for any extreme increase in MPG.
I wonder what percentage of the fuel used in a typical car is turned into heat as opposed to what percentage is actually turned into kinetic energy (moving the car)
PostPosted: Sun Jan 07, 2007 2:02 am
Images: 1
Thats very interesting!...I kinda wondered the same.
PostPosted: Sun Jan 07, 2007 2:24 am
Here's a college students web site.... :lol:
http://ffden-2.phys.uaf.edu/102spring20 ... 20Main.htm
Not sure how accurate it is, but it's a good read.....
This means that for a stock engine, only 20% of the power in fuel combustion is effective.
PostPosted: Sun Jan 07, 2007 2:29 am
Images: 1
Link dont work!...So..What if we could increase it to 50%?....How much more power would be useful?...How could we do that increase?
PostPosted: Sun Jan 07, 2007 2:34 am
all you had to do was copy and paste it...but anyways...I had to find out what the entity number for an apostrophe was, should work now.
PostPosted: Sun Jan 07, 2007 2:37 am
Here's a reliable source.
The efficiencies of good modern Otto-cycle engines range between 20 and 25 percent—in other words, only this percentage of the heat energy of the fuel is transformed into mechanical energy.
PostPosted: Tue Jan 09, 2007 1:54 am
http://users.penn.com/~tomwflye/gas.htm
