It is currently Wed Nov 25, 2026 7:31 am
 Page 1 of 1 [ 8 posts ]
 Post subject: Turning Signals
PostPosted: Fri Aug 11, 2006 10:14 pm
I'm not sure what happened, but when I try to use my turn signals on my car they don't work. I tried the hazard lights thinking that a bulb might have crapped out, but they work fine. I also tried the other functions on the stalk--my cruise control and my wipers work but my high beams do not. I also checked my fuses and they're fine. Can someone help me out on this?
 Post subject: Re: Turning Signals
PostPosted: Tue Nov 21, 2006 8:32 am
I'll try this again--it's been real frustrating for me to try to solve this problem. My guess is that there is a shorted-out wire somewhere either in the steering column or the stalk with thecruise control. Does anyone out there have any suggestions as to what this problem might be??
Cadillac--the rich man's Oldsmobile!!
PostPosted: Tue Nov 21, 2006 8:37 am
Try replacing the flasher units. They are cheap, and worth a shot. Otherwise you are looking at (most likely) a new turnsignal lever assembly.
PostPosted: Tue Nov 21, 2006 10:49 am
Try replacing the flasher units. They are cheap, and worth a shot.Otherwise you are looking at (most likely) a new turnsignal lever assembly.
Can I get those flasher units at any auto parts store? How difficult are they to install?
PostPosted: Tue Nov 21, 2006 6:52 pm
You should be able to. They are the round 'things' in your fuse box. They install like any other fuse.
I replaced one in my old truck about 5 years ago- ran me maybe 5 bucks? There are 2- One for the left, one for the right, IIRC.
PostPosted: Tue Nov 21, 2006 10:43 pm
Andrewk, your car has one flasher for each direction? I think you'll find the other one controls the hazard flasher...
PostPosted: Tue Nov 21, 2006 11:09 pm
That was my first instinct. Why I changed it afterwards, I dont know... you are correct. One is for the hazards.
PostPosted: Fri Dec 01, 2006 1:15 pm
Sorry it took so long for me to reply to this. I did buy the flasher unit (for $3) and that solved my problem. The only problem I had was trying to find the thing under my dash with all those damn wires surrounding it!!! Thanks, guys!!!
