It is currently Wed Nov 25, 2026 11:46 am
 Post subject: CV joint replacement?
PostPosted: Sat Sep 08, 2007 11:07 am
How much does it cost to replace the front left CV axle on a
1994 Olds ninety-eight. Shade tree mechanic offered to do it for $200.
How hard is it to do it yourself?
PostPosted: Sat Sep 08, 2007 11:14 am
its very easy but you can pay someone 50-85 bucks labor to do it for you parts should be 60bucks for the axle. Rule of thumb If youre going to have a shop do the work buy your parts youreself its alwasy cheaper. If youre mechanicly inclined then i can give you step by step details.
PostPosted: Sat Sep 08, 2007 2:45 pm
destineal wrote:
How much does it cost to replace the front left CV axle ........
Prices will vary by geographical area, and locally from shop to shop. I suggest you check the shops in your area.
........ How hard is it to do it yourself?
Depends on your knowledge/experience level. The more you have, the easier it gets.
It's not possible give a more specific answer without knowing your capabilities.
PostPosted: Sat Sep 08, 2007 3:01 pm
91buickman wrote:
........ If youre going to have a shop do the work buy your parts youreself its alwasy cheaper.
Hard part will be, finding a shop that will install parts from a source other than their own supplier.
Many, if not all, will add, at least, a portion of their legitimate markup to the labor charge.
If/when you do find a shop that meets the above qualifications, it is doubtful they will warranty/guarantee any part of the job.
PostPosted: Sat Sep 08, 2007 3:07 pm
Tools:
36mm Cv socket
Breaker Bar 1/2 inch drive
(the above can be rented from autozone for free)
You will need a 10mm socket, a 14mm or 9/16 deepsocket
(side note: some GM's have a 21mm bolt head with a 15/16(24mm) Nut. others have a 15/16(24mm) nut&bolt.) and 18mm socket,
whiteout
A good piece of pipe at least 11/2 to 2 feet long.
Pry bar, and a hammer
after you loosen the wheel jack it up and get it on a jackstand. spray wd-40 or PB blast on all bolts. Proceed by loosening the 2 brackets on the strut that hold the brake line and speed sensor line in place with the 10mm socket. proceed by loosening the stabilizer end link with the 14mm socket and remove the endlink. now take a deep breath and attach the 36 mm socket to the cv axle bolt attach breaker bar and pipe and rotate counter clock wise, and remove nut.Also use white out at the strut/spindle bolts and spindle so the line meets to make sure your alignment will not be affected when you put the spindle back in. Take the tie-rod bolt off with the 18mm socket and hit the spindle area where the tie rod meets with a hammer a couple of times, the tie rd will seperate it self without damage move it to the side, take the strut to spindle nuts and bolts with the 15/16(24mm socket, youll need to hold one end after loosening with pliars. after removal slowly let down the control arm you will be able to pull the axle out of that end. Now use a pry bar at the the part where the trans and cv joint meet with one hand, with the other hand rotate and push in and out on the Cv shaft all in one fluid motion. It will take a couple of hard yanks but it will come out. VERY IMPORTANT when you re-install the new axle MAKE SURE THE IT "CLICKS AND LOCKS INTO PLACE!!!" you will hear and feel this action to. After that reverse the directions, Grab a beer and watch tv if you need some pics i think i can dig some up.
PostPosted: Sat Sep 08, 2007 3:27 pm
I would add, to the list of tools-
An impact wrench. Much easier to use than a breaker bar. If you don't have a friend with one, it may be one of the most valuable investments you ever make. Harbor freight makes affordable ones, if you won't use it much.
A pickle fork. This is used to properly separate the tie-rod end.
A FSM, if you don't already have one. And use any other tools it recommends, that aren't mentioned here.
PostPosted: Sat Sep 08, 2007 3:37 pm
Thanks for all the replies. Took me forever to find a good Oldsmobile forum. It's good to be home.
PostPosted: Sun Sep 09, 2007 2:52 am
If you dont do serious work on your car a impact wrench isnt a good investment, a breaker bar does fine, Pickle forks will tear up the rubber boots on the tie rod. Thats why you a couple of light strikes with a hammer on the spindle will instantly loosen the tie rod with no ill effects. that my firend is the proper way to ensure no damage is done.
PostPosted: Sun Sep 09, 2007 11:31 am
Depends on if you want to work smarter or harder I guess.
There are easier ways, such as a cheaper impact wrench, that still wont break the bank. And it will come in handy later, if he ever needs to do any other suspension maintenance.
Only if you don't know how to use one. I have never torn a boot on a tie rod using either an air pickle, or one you hit with a BFH. The key is to get it under the boot, not on it. It is one of the reasons a pickle fork is tapered. The reason they make pickle forks is for suspension removal, such as tie rods, ball joints, etc.
Not always. Sometimes things stick together, which is why he should get the right tool, instead of beating on the spindle until it lets go.
If it were the "proper" way, the FSM wouldn't tell you differently. Your method probably works, but the OP should know what the proper tools are to do the job, and the proper way to do it.
PostPosted: Mon Sep 24, 2007 7:36 am
Do I need to replace the axle nut if I'm just going to put the same cv back on?
PostPosted: Mon Sep 24, 2007 9:39 am
Only if it's damaged.
PostPosted: Tue Sep 25, 2007 2:07 pm
Where's the stabilizer end link?
PostPosted: Tue Sep 25, 2007 2:22 pm
PostPosted: Wed Sep 26, 2007 9:14 am
Got The CV axle off. going to put the same one back on, but do I need a new Drive Shaft Seal or can I leave the old one in(put in earlier this month or late last month)
PostPosted: Wed Sep 26, 2007 10:03 am
using the same on is fine, there very durable just make sure the axle "Clicks and lock" into place, and take your time.
