It is currently Fri Nov 13, 2026 1:17 am
85cieraholiday
 Posted: Thu Mar 25, 2004 7:05 pm |
Whats everyones HP and torque raitings? Mine are:
92hp@2800 rpm, and 134lbs/torque@4400 rpm
_________________ .
86Delta
 Posted: Thu Mar 25, 2004 9:27 pm |
not as much as i'd like @ any RPM
TheDarkShadow
 Posted: Thu Mar 25, 2004 10:02 pm |
Joined: Sat Jan 17, 2004 11:26 pm Posts: 113 Images: 12 Location: Virginia Beach, VA
My Delta 88's 307 is about 140hp and 250 torque from the factory, 20 years and 175k miles later, who knows now, plus i got an edelbrock carburator and accel supercoil on it too, so i diffentnly don't know :?
My 455 i got sittin on an engine stand has about 350hp
_________________ -Shadow's Rides-
Psyco Diver 69
 Posted: Thu Mar 25, 2004 10:45 pm |
Mine is rated at 200hp and 300 something tq. The Paw 214/224 cam, headers, and edlebrock RPM intake that I will be putting on should push my to shy of 300hp at crank. Next winter when I do my motor rebuild and build up I should push about 400-425hp at the crank.
The Cutlass is pushing 110hp and 190tq
_________________ Jake 19/m
1972 Olds Cutlass- Parts car
DKnight
 Posted: Fri Mar 26, 2004 1:15 am |
Mine is rated 165hp and 215ft/lbs stock, but with my mods, I'll safely estimate 190-200hp and 230ft/lbs. Those are from my SOTP dyno, and comparing my car's performance to other cars of the same year.
DK
_________________ One man can make a difference. One man made all the difference.
BigBlockOlds
 Posted: Fri Mar 26, 2004 1:59 am |
Roughly 325hp/450ft-lbs
468/T-56/3.73
 Posted: Fri Mar 26, 2004 9:12 am |
165hp / 215ft/lbs
but what good is all this torque when you have a car that weighs in excess of 3500 lbs???
strokercutlass
 Posted: Fri Mar 26, 2004 10:43 pm |
| TOC Mechanic |
Quote: but what good is all this torque when you have a car that weighs in excess of 3500 lbs???
(In a wise, sensei master voice)
Ahh, young grasshopper...you have yet to learn the ways of the Olds V8  Weight is NOT an issue!
Vista: stock 350 2 barrel not sure but it pulls 4,200 lbs around pretty good!
442: 400 Olds with 455 heads, Edelbrock intake, 750 DP, headers and duals..haven't had the car long enough to get any road time on it..still has some issues I'm working out.
Cutlass: 600 hp/620 ft.lbs torque
88Ciera_SC
 Posted: Sat Mar 27, 2004 2:22 am |
Horsepower- 160 @ 4000 RPM
Torque(lb-ft)-215 @ 2750 RPM
these are factory ratings and i've been told that there not correct.
that is, GM made the numbers lower then they actually are..
best thing about this engine is the low torgue rpm's.
also on the DOHC question.
I had a 1992 grand prix that had a 3.4L DOHC.
1988 Cutlass Ciera SC
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
DKnight
 Posted: Sat Mar 27, 2004 2:25 am |
Just mod it up some more and drop some weight.  You can boost that torque up. In fact, I bet with that intake, you have at least 10 more pounds of torque, maybe 15. I know this - my own intake dropped my 0-60 times by between .3 and .5 of a second, depending on conditions. Sounds wild, but it's true. To change a 0-60 time that much, it takes a real power increase.
DK
 Posted: Sat Mar 27, 2004 2:27 am |
DKnight wrote: To change a 0-60 time that much, it takes a real power increase.
Nitrous Oxide! (a.k.a NOS)
85cieraholiday
 Posted: Sat Mar 27, 2004 10:26 am |
nwmaximus wrote: Got a '78 Cutlass with a 76 350 Olds.Anyone care to guess what my HP & TQ are? Only mods as yet are K & N filter,th-350 B & M shift kit,& fresh air feed to air cleaner.Have a set of headers & a dual exhuast job coming soon.That is after the PST poly front end rebuild,and Eibach springs.
Your hp and torque ratings are-1976 350 v8 cutlass-170hp@3800 rpm and torque-275lbs@2400 rpm
These are the factory figures for the optional 1976 350 V8
Hope I was able to
_________________ .
