its a 2 channel amp it has Stereo, bridged mono or Tri-Way output
MOSFET Circuitry
Three way protection-DC, short circuit and thermal Power
Light Strip-A six segment LED that lights up when power is turned on
Built-in Electronic Crossover Network with Continuously Variable Low or High Pass Operation
Variable gain control
Filter switch-Select low pass, off (full range) or high pass. The slope is 12dB per octave
X-over frequency control-Variable adjustment knobs allow you to select a crossover point of 40Hz - 500 Hz for the low pass or high pass crossover
Variable 18dB Bass Boost-
Stable to 2 Ohms Stereo 4 Ohms Bridged
High and Low Level Inputs
Anti-thump circuit for quiet turn on/off
Accepts up to 4-gauge power and ground wire
Accepts up to 6-gauge speaker wire
Adjustable Input Sensitivity
THIS WILL GIVE U A IDEA OF WHAT IT LOOKS LIKE TILL I GET PICS IT BTHE SAME ONE BUT A LITTLE LONGER
