It is currently Fri Nov 06, 2026 9:45 am
PostPosted: Mon Jul 26, 2004 4:02 am
My 70 442 has front disc and rear drum brakes. In 70 a metering valve was used at the master cylinder in conjunction with a seperate proportioning valve on the frame.
In 71 they used a combination valve which incorporates a metering valve and proportioning into one unit.
Can I remove the 2 valve system and replace it with a 71 combination valve with no other modifications?
Thanks,
John
This was my father's Oldsmobile!
PostPosted: Mon Jul 26, 2004 3:37 pm
Hi blonzz, all
ROP would be better for this type question. Do you see an advantage to making this change? Just wondering as I'll likley not change anything on my '70.
PostPosted: Tue Jul 27, 2004 5:49 am
Hi blonzz, all
Norm,
I need to change the proportioning valve on my car. I figured I would just change over to a combination valve.
John
PostPosted: Fri Jul 30, 2004 4:30 pm
brake systems were pretty straightforward back then so i don't think it will be a problem changing to the combination valve. also, while you are doing all that brake line plumbing, why not toss a line lock in there?
Users browsing this forum: Bing [Bot] and 12 guests
