It is currently Mon Nov 16, 2026 4:38 am
 Page 2 of 4 [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Feb 24, 2005 9:45 am
make sure the ignition gives off 12V where it should when you turn the key to ON. This is likely the problem, check ALL of your fuses! The one fuse I'm thinking in particular is the ECM fuse. This would defiantely cause a total and instant dead car as you describe!
PostPosted: Thu Feb 24, 2005 12:52 pm
But it does turn over..... :?
PostPosted: Thu Feb 24, 2005 5:41 pm
Sorry... Should have clarified. The car might have power to the starter, but not to the ECM or to the coil pack. This would result in the situation he is seeing, but would not be the only cause for sure :-)
PostPosted: Thu Feb 24, 2005 5:50 pm
Images: 27
Is it just one of the wires has no sparks or all???
if it is all I would look at your ICM.
PostPosted: Thu Feb 24, 2005 9:02 pm
Checked ECM fuse with ohmeter and is fine.
Did not check all wires for spark.
PostPosted: Fri Feb 25, 2005 9:48 am
I wonder if it would be giving you a code right now because of all this. Do you know how to retirieve codes from your ECM?
If you've got a dead coil pack, the ECM might possibly be seeing this. Or at least give you a hint in the right direction?
PostPosted: Fri Feb 25, 2005 10:55 am
I've got a Haynes manual on how to use the jumper wire method and it shows the codes.
I'm going to try that as soon as I get back to the car tomorrow night.
PostPosted: Fri Feb 25, 2005 1:38 pm
Sweet deal... Let us know how it goes.
PostPosted: Sun Feb 27, 2005 10:05 pm
Ok, here's the trouble code I retrieved from the ECM:
Four flashes, pause, three flashes - Electronic Spark Control (ESC System)
Check wire leading to ECM terminal L Check the wiring connector at the ECS controller and at the ECM. Check wire from knock sensor to the ESC controller; if nessesary, reroute it away from other wires such as spark plug etc. Replace the knock sensor*
*Indicates component replacements may not cure the problem.
I was only at the car for five minutes when I did this test. I didn't get a chance to check as it described.
What do you guys think?
PostPosted: Sun Feb 27, 2005 10:44 pm
Oh and another thing, if a knock sensor is bad in a vehicle, would that make it not start?
PostPosted: Sun Feb 27, 2005 11:59 pm
I would suspect the Ignition Control Module to be faulty. Check ALL spark plugs for spark. If none of them spark, it must be the Ignition Control Module, as it's unlikely that all 3 coil packs are dead. With the code 43, the ECM will retard the spark timing by 10 degrees, but this very well may have been set because of the not starting issue. The knock sensor adjusts a 5 volt signal sent to the ECM, it will not prevent spark.
PostPosted: Mon Feb 28, 2005 7:48 am
If there are more plugs producing spark besides the one I checked, wouldn't it act like it wanted to start?
And is the ignition control module a common culprit of starting problems? How often do they go bad?
And if the trouble code 43 hasn't got anything to do with the car not starting, should I do like it said and replace the knock sensor anyway?
Thanks guys
PostPosted: Mon Feb 28, 2005 9:20 am
until you know for sure, maybe a used knock sensor is in order (no idea what they're worth)
Brando may be on to something, the ICM may not be functioning. This would produce no spark, because you dont have any instuctions for the coil packs. You didnt kick the wires under the dash when getting out of the car last did you? That might cause problems like this... Not saying that you're destructive or anything :-)
PostPosted: Mon Feb 28, 2005 10:39 am
Kick the wires? Nope.
I think I'll put a new ignition module on it and a knock sensor and cross my fingers.
PostPosted: Mon Feb 28, 2005 11:07 pm
Hi Oldsmowbill, all,
You might want to find out what it does before you change it.
Hint: It's only used when the engine is running and under load.
You could make it a genuine learning experience if you did some research and found out what each part does before you decide to change it.
It's an excellent way of "learning the basics", it's how I learned.
Or you could just change everything at once and be done with it. :lol:
