It is currently Mon Nov 09, 2026 2:28 am
PostPosted: Tue Oct 11, 2005 10:28 am
I just replaced my engine and transmission. I had taken them both out of the car, sent the trans back to the manufacturer, but the engine sat for about 2 months before i got the new trans. After putting the enine and trans in, the engine gives errativ power when driving. here is what it does: it starts and idles fine, it even revs in nuetral fine. but when in drive the engine gives ver erratic power, and sometimes makes a 'huffing' noise that comes from te intake, in which case the rpms drop dramatically. I feel like it is an electrical prolem. any ideas???
-alex
1991 3.8L 231cid V6
custom cold air intake
strut bar
PostPosted: Tue Oct 11, 2005 1:52 pm
A Huffing noise coming from the intake? The intake manifold or the throttle body?
PostPosted: Tue Oct 11, 2005 3:14 pm
if by the throttle body you mean the air filter assembly then yes. It sounds like the engine is spitting air out the intake
1991 3.8L 231cid V6
strut bar
PostPosted: Wed Oct 12, 2005 9:00 am
well... Check the connections to the IAC motor (IAC = Intake Air Control), which regulates air flow to the engine when warming the car up. When the IAC is on, I can hear what sounds like a hissing coming from my air filter.
You likely have the same engine as mine being your is 1986, and thats the only thing I can think of that would cause a sound like that? It would make sense that if this motor valve isnt hooked up that increased suction would pull it closed, choking off your motor? Just a suggestion.
