It is currently Mon Nov 09, 2026 2:48 am
 Page 1 of 1 [ 6 posts ]
 Post subject: Driver side window
PostPosted: Wed Oct 12, 2005 7:37 pm
hey guyz ever since i bought my ciera the driver side window has not worked right ive heard this has happend with quite a few olds basically u role it down and its goin by itself and it stops about halfway or so on the way down u press the switch again and nothing happens ive noticed the longer u let it set without touching the switch the further the window will move so for about 9 months or so ive just been helping it up and down and it seems to work i may have the problem fixed 2morow as im taking it to my school to work on if any of you know what this is plz tell me so i may be able to get it fixed instead of checkin all the stuff for 2 hours before i diagnose the problem thx -Intimidator68
PostPosted: Wed Oct 12, 2005 7:58 pm
Wow, that was very hard to read, no offense. Anyways, sounds like the window motor is on its way out or could be a bad switch. About the same thing is happening to my Delta, so I know how irritating it is.
 Post subject: Re: Driver side window
PostPosted: Thu Oct 13, 2005 12:33 am
It could be anyone of the components in that circut. It is impossible to tell over the net what it is, as it could be as simple as a wire or ground or as major as a motor. That also includes the mechanism the motor operates. Sorry I cant help, but remember to start simple.
PostPosted: Thu Oct 13, 2005 12:46 am
that is what i will be doing. i knew it could be a number of things. i was just hoping that it was a more common problem with the a-bodys (like somethin that might have been recalled in a since) but i guess not everything comes ez. -intimidator68
PostPosted: Thu Oct 13, 2005 1:35 am
My old Jeep Larado burned out a window motor after running slowly for a while. When I took the door apart (shoulda done it months before :blush: ) I found the track grease had turned into a hard and crusty mess in the tracks. Months of poor-to-no track lubrication stressed the motor for too long.
C.J.
PostPosted: Thu Oct 13, 2005 9:20 pm
Well me and a few of my class mates got to test all the components to the driver side window today. we checked the circuit breaker, pcm, the switch, and they were all good. we checked the motor and it was putting out a very very high amp reading. :( the motor is just worn out. because of the high amps it was tripping the circuit breaker after about 3 or 4 seconds of use. i wish it was somethin simple as in a loose connector but cant get everything ur way. -Intimidator68
p.s. how much will a new window motor cost. thx
